Home > In Car Electronics > Focal Speaker Upgrade |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
Few images here:
https://www.defender2.net/gallery/thumbnails.php?album=1095 Also added a aux fuse box to support the sub: https://www.defender2.net/gallery/thumbnails.php?album=1096 tags are backards |
10th Feb 2013 5:51pm |
ethanicus Member Since: 11 Jan 2013 Location: Surrey Posts: 94 |
Thanks buddy. All corrected.
10th Feb 2013 5:56pm |
The Alpine Sub looks neat and a good fit, would it not mount the other way up?
(Upside down writing would annoy me) |
11th Feb 2013 8:39am |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2634 |
i think i need a bigger sub... to keep up with the focals that is, there mad!
11th Feb 2013 12:03pm |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1413 |
I know exactly what you mean.
Just have a play around though, I turned my amp down to about a third, and ths gain on alpine active sub all the way up and set the filter low low low. Works quiet well now, but it also alters depending on music and formats. Going for a proper sub set up is nice, but would be another £4-500 and then not as practical for me. I am still undecided but by playong around have got the sound alot better |
11th Feb 2013 12:11pm |
mlightfoot Member Since: 10 Jan 2009 Location: Cheshire Posts: 86 |
Looking at fitting this and had hoped to locate it on the back of the cubby but it seems too long. Where did you locate the iBus 2.1? Thanks M |
19th Aug 2015 8:34pm |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2881 |
I have a Focal kit to fit in the front... read over this but can you give me a guide to wiring these, what connectors do i need to run and get for example? How do you coneect up the cross over? Cheers Andy Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
26th Jan 2016 3:18pm |
I take it the 2 wires on the left are the tweeters? What are the other connections wiring? Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
26th Jan 2016 3:25pm |
Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630 |
From left to right (as your looking at it) Tweeters, Mid and Input...
Cheers Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
26th Jan 2016 4:37pm |
Thanks Tim,
Sorry for the daft questions but the input wires come from where?? Do you have to make up new cables from the cross over to the focal speakers, and then ditch the LR cables to the current speakers?? Andy Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
26th Jan 2016 5:55pm |
Are the inputs just the factory tweeter/woofer positives and negatives?? Andy
26th Jan 2016 6:17pm |
The tweeters come with wire attached.. (all you have to do is put a connector on)... You have to make up the mid range cables and you just use the mid speaker wire with replacement connections for the inputs..
Hope that makes sense!! Cheers Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
26th Jan 2016 6:39pm |
All sorted Andy
26th Jan 2016 7:57pm |
