Home > In Car Electronics > Focal Speaker Upgrade
Page 1 of 4 1234>
ethanicus
2014 Defender 90 Puma 2.2 XS CSW Corris Grey
Hi All,
After a week of ownership Im loving the D90. However the factory speakers are C**P. As Im a fan of Focal I decided to fit a set of K2 KRS 100 in the front and PC100 in the rear. What a massive improvement over the standard setup. I know speakers have been done to death put I thought I would share some pics to help those that are thinking about doing it. I wanted a factory look so kept the standard 4 setup.
Fronts
Rears
More pics in the my gallery.
https://www.defender2.net/gallery/thumbnails.php?album=1076
Next stop active sub, to cover the low range. Thumbs Up
Post #206360 28th Jan 2013 9:35pm
Killer90
Site Sponsor
good choice Thumbs Up Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #206362 28th Jan 2013 9:38pm
Likeomg
are they a direct plug and play replacement or is additional wiring needed?
Post #206365 28th Jan 2013 9:39pm
Alive Tuning
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Havana
Best driven off an amplifier. I've done the same upgrade, but with 13cm polyglass VRS speakers, and a Rockford Punch amp. Mr. Green
Post #206371 28th Jan 2013 9:46pm
ethanicus
Rears = Straight swap
Fronts
Tweeters are pre wired but need connecting to the crossover (pictured)
Existing speaker connection need changing for forks and simply connect to the crossover . Then create a small link cable for the mids.
Velcro crossover to inside of dash. All installed in under 1.5 hrs.
When I dyno mat the rear I will replace the speaker cable as the factory is very thin.
Post #206372 28th Jan 2013 9:46pm
ethanicus
I will in the future, I just need a quick win to get me by,
Post #206375 28th Jan 2013 9:47pm
SGH
I have same front upgrade ready to fit and bought iBus 2.1 under seat sub to add to the system.
Fitted sub today and decided to run the cables under vehicle rather than inside to make a neater install.
Where did you fit the crossovers as not much room on offside
Simon
Post #206376 28th Jan 2013 9:48pm
ethanicus
Just inside the dash againt the section by the door. You need to clean well as its a bit dusty inside.
I think imgoing for a Alpne SWE-1200 as a friend has one and it seems to work well with the focals. How did you run the sub cable from the head unit?
Post #206381 28th Jan 2013 9:53pm
SGH
iBus 2.1 is ISO connection comes with a 3mtr lead.
Post #206384 28th Jan 2013 9:55pm
SimonR
I have an Alpine sub, intended to fit under lesser car seats which have more room. Mine is under the rear seat and has made a tremendous difference to the sound. I have Alpines in the dash too but they made less of a difference - still good though.
Si
Post #206388 28th Jan 2013 10:02pm
Re: Focal Speaker Upgrade
ethanicus wrote:
Neat. Cool How did you gain access to position the cross overs again? Did you pull the dash back a bit or go though the speaker holes? NEVER SURRENDER! ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #206391 28th Jan 2013 10:05pm
ethanicus
Thanks
All installed via the speaker hole. No need to disturb the dash. All I did was cable tie the old tweeter cables to stop vibrating.
Post #206392 28th Jan 2013 10:09pm
That's a good idea with the cable ties. On a rough road it can be highly annoying cables vibrating I have a heck of a lot behind there so I know.
How did you get on on the off side with the heater vent tubing in the way? Or was there enough room around that?
Thumbs Up NEVER SURRENDER! ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #206405 28th Jan 2013 10:38pm
Killer90
Site Sponsor
ethanicus wrote:
Thanks
exactly what i did, i insulated mine and used double back foam to stick it to the inside of the dash up through the speaker hole Thumbs Up Thumbs Up CSK Automotive
Post #206406 28th Jan 2013 10:39pm
ethanicus
Great minds.... Thumbs Up
Post #206416 28th Jan 2013 10:46pm
Page 1 of 4 1234>
