![]() | Home > Puma (Tdci) > Puma oil spec? |
jamesbond007 Member Since: 28 Oct 2009 Location: Central Algarve - Portugal Posts: 172 ![]() ![]() ![]() |
It's in the owner's manual. Boldly going nowhere
Discovery 3 after a Defender 110 Crew Cab TD4 and a 1964 SIIA 88 Regular. |
Its 5w30 castrol magnatec, I think its about 7 Liters, but the dealer will just put there own 5w30 in and it wont be castrol
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 ![]() ![]() |
make sure its the Magnatec Professional which is the semi synthetic and has the Ford aproval Puma 110 - gone
Series III 1973 - going strong |
5W30 WSS-M2C913-B Boldly going nowhere
5W30 WSS-M2C913-B = ACEA A1/B1 (A1/B1 are Much better)
ACEA A1/B1 is superseded by ACEA 2008 A5/B5 (much better) Conclusion: in our Ford engine USE ACEA A5/B5 specs. oils So you can use Mobil1 5W30 ESP Formula (The best!!!) or Motul 8100 Eco-nergy 5W30 or Castrol Magnatec A1 Professional 5W30 in my opinion Mobil1 are better than Motul and Motul are better than Castrol. see HERE . Note that VW 50700 spec are wider than A5/B5 and Mobil1 ESP cover the VW50700 Spec. Ford ..913-B, A1/B1 and A5/B5 are olis with LOW HTHS for low consumption but....... Daniele p.s. my opinion is the Diesel GURU opinion ![]() ![]() ![]() IID Pro MV License |
austen Member Since: 10 Mar 2008 Location: Sydney Posts: 52 ![]() ![]() ![]() |
I have just checked the Castrol website here in Australia, and they recommend 0-40 Edge. The handbook says 5-30, and neither of these Castrol oils comply with the spec in the book.
I am confused. Austen. Rover 12 1935 Rover 20 1940 Rover 100 1960 Defender TDC1 2008 FL2 TD4 2008 |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2450 ![]() ![]() ![]() |
Higher specs (like Dgardel quotes) doesnīt mean it is better.
Example: V12 (2-stroke) Detriot Diesel engines mounted on drilling rigs or power generators needed only API-CC spec. Many people made the mistake to use the higher spec API-CD on them. Guess what? The thing with Fordīs oil specs for defenders resides on the fact of fuel economy bussiness by using Low-HSHT values. I would prefer, however to use a High-HSHT in detriment of fuel economy. So these are the 2 cases where I see the manufacturer being so strict with oil specs. Puma 110" SW ............................................................. Earth first. Other planets later |
I'm not totally agree with you, if you compare the same specific specs, the oil IS better! ACEA A5/B5 IS better than ACEA A1/B1 Please explain me why API-CD isn't better than CC spec. In other case spec ARE different so you cannot compare it totally eg ACEA A5/B5 with ACEA A3/B4.
High HTHS IS ALWAYS better than low HTHS, in my opinion and experience. I use Mobil1 high HTHS on my Defender (Mobil 1 ESP Formula M 5W-40). Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
[quote="dgardel"]
I'm not totally agree with you, if you compare the same specific specs, the oil IS better! ACEA A5/B5 IS better than ACEA A1/B1 Please explain me why API-CD isn't better than CC spec. Well Iīm not a specialist. Ash content of CD oils killed the engines. Higher spec, but not good at all for that engine. Puma 110" SW ............................................................. Earth first. Other planets later |
badwookie Member Since: 07 Feb 2010 Location: kuwait Posts: 25 ![]() ![]() ![]() |
What about oil spec for an extreme summer climate like kuwait's (50 Celcius and above during the hottest months May through August) ?
LR Dealership in Kuwait uses 10w-60...Mobil-1 10w-60 has a Viscosity Index (V.I.) of 177...While Mobil-1 5w-30 V.I. is 164...
Does a higher V.I. mean a better oil spec for the Puma ? |
Duckhams Q .....................bloody marvellous. Original Member Pie n Pea Club.
110 HCPU Tipper |
jlerra Member Since: 10 Jul 2009 Location: Gibraltar/London Posts: 149 ![]() ![]() ![]() |
Hey Guys,
Why don't we comply with what it says in the 'book of words' - Castrol Magnatec 10/30! However, if in Dubai - check with Tech Dept at Land Rover. In Gibraltar and Andalucia where it is hot in summer, I use what it says in the book and it's fine Tra-la-lu El Pepe Flamenco JLS 'El Pepe Flamenco' |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2660 ![]() ![]() ![]() |
LR South Africa uses Castrol Magnatec 5w50
