![]() | Home > Puma (Tdci) > Puma oil spec? |
LESVOSD110 Member Since: 19 Aug 2009 Location: South Africa Posts: 241 ![]() ![]() ![]() |
I don't even look at API as there standards are very low.It's a fuchs oil. Puma 110 SW 90 V8 SOFT TOP |
Thanks! So, what oil do you use? And how does it compare to the Magnatec 5w30? |
Naks.
I forgot,what beer do you drink?No imports please. Puma 110 SW 90 V8 SOFT TOP |
Castrol Magnatec low HTHS is named Professional A1. Normal Magnatec is A3/B4 or only c3 or only b4 or............. Another study that showed top ring wear rate increased by the factor (3.5/HTHS)^2.15 for the HTHS viscosity range 2.7-3.5. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
![]() In Mauritius (where I was born), Phoenix. In SA, Castle Lager ![]() |
Excellent.I was born and farmed in the Eastern cape,East London.Could you please have a few when you braai sometime.I make my own Biltong,Droewors and Boerewors but no Castle to be found. I wonder if Caslte will be good for the Puma? Puma 110 SW 90 V8 SOFT TOP |
Ah, good old Slammies. I spent 10yrs at Rhodes University, so visited EL quite often.
Can't see why not ![]() |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 ![]() ![]() ![]() |
What do you think about " Total Oil Synthetic Plus" 5w30 ACEA 2002 : A5/B5 " and "Carrefour Synthetique Motor Oil" 5w30 ACEA A5/B5 ?
Does anybody know of these oils ? Thanks |
It seems strange to me that you have such a range of 'supermarket' oils in the EU. In SA you only get the well-known brands, so we tend to stick to them. Personally I would spend more putting the best engine oil possible in my landy because I intend to keep it forever. My advice: only use the known brands - Castrol, Shell, Mobil, etc. |
sasha2001 Member Since: 02 Jan 2009 Location: New Zealand+ russia Posts: 206 ![]() ![]() ![]() |
we have recently got this oil in 5 litre packs in New Zealand instead of drums etc
mobil1 with supersyn, meets ACEA A1/B1 and A5/B5 ford WSS-m2c929-a Is this oil ok, appears to be on paper link here http://neptune.spacebears.com/cars/stories/mobil1.html and I think this is the same Oil but not sure? http://docs.google.com/viewer?a=v&q=ca...jeWJnQ1blQ |
Thank you MK Happy Landrovering!!!!!! |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 757 ![]() ![]() ![]() |
Just to revive this a bit, why the specific spec on the oil? Aren't our trucks supposed to be able to go to the most remote parts of the world and what not? If you do go to such places, I doubt you'll find the proper spec oil when and if you need it.
That being said, here in the Philippines where I happen to be at the moment, the proper spec oils are as rare as hen's teeth and most oil dealers, local and importers are sometimes difficult to deal with and convince to get the oil so sometimes I have to make due with what I can find. (The closest spec possible, of course) Recently, Shell released a "newer" version of their Helix oil so from 5W-30 the new one is 5W-40, still good then? I'm asking the local Shell guys if they have the Helix Ultra Professional AF 5W-30 as that is what comes out with their oil matcher on their website. Still no news though. Some of the local 2.4 Pumas have run the local Shell 5W-30 no problems, or so I've been told so I guess I should be good? Last edited by HardCharger on 27th Feb 2015 2:51am. Edited 1 time in total |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2303 ![]() ![]() ![]() |
Hi All
Just read this thread... and are some what nervous about posting... but here goes ![]() 1 1/2 years ago I decided to replace my 300tdi and buy in 'near the end' of the current Defender, after a long look (and research) I decided to go for the latest, best condition, 2.4tdci with the lowest mileage I could find. In the knowledge that I was going to 'sort' it as best I could into a a quiet / comfortable, long distance vehicle. DIY Servicing was also a factor. I think the what Oil Question ![]() but for the 2.4 isn't it more simple ![]() I appreciate that some have 'Brand Preferences' mine is based on nothing more than I have have driven around 250K miles in Land Rovers all on Castrol. This is whats in mine... have I got it wrong ![]() ![]() Click image to enlarge ![]() Click image to enlarge SKIP https://www.defender2.net/forum/topic83242.html |
X4SKP, that oil meets the specs, so its fine. --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
