Home > Td5 > TD5 Clutch Pedal Mod |
drive4change Member Since: 15 Aug 2012 Location: Somerset Posts: 193 |
Stupid question time....
Is this mod good for td5 only or is it possible to do something similar on earlier defenders? I.e. 200tdi? |
11th Nov 2012 8:12pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6092 |
I fitted this spring to my old 300Tdi 90 (although I did build this vehicle, so used a variety of parts)#
IIRC however, my old company car (300Tdi 110 CSW) had that spring on it from new. |
11th Nov 2012 8:53pm |
238kirk Member Since: 03 Nov 2012 Location: Doncaster Posts: 233 |
fitted this kit today after reading this thread and i have to say its well worth the £20 and easy to do
19th Nov 2012 3:53pm |
Captain Crash Member Since: 07 Aug 2012 Location: Hayling Island Posts: 3 |
Did this job today on my 2001 TD5.
The only thing I would add to the thread is that not all genuine Land Rover DCP3212L bushes are created equal! One had a 3.5mm hole and slipped easily onto either end of the spring. The other had only a 2.5mm hole and had to be drilled out. Fortunately I discovered this before fitting, so it was an easy fix. I found it tricky to get the second side of the spring into the bush, but well worth it. |
5th Dec 2012 11:19pm |
markespark Member Since: 20 Sep 2012 Location: Huntingdon Posts: 85 |
Just fitted the pedal mod - only took about half hour all in, very pleased with the result.
Very good advice on here thanks to all who posted |
8th Dec 2012 3:06pm |
NickEJ Member Since: 24 Nov 2012 Location: Ljubljana Posts: 152 |
I also did mine yesterday but took a little longer due to difficulties getting access. I have the air conditioning so getting to the strip which holds the carpet is difficult so I resorted to working around it. A little frustrating but the result is very pleasing. I won't mind sitting in a traffic jam now!
Cheers all for the guidance! |
9th Dec 2012 12:17pm |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 |
Just done the pedal mod this morning. It took just over an hour to do. Funny how I love the carpets, air con, extra luxuries While I am driving, but always curse them when I work on the car, muttering things like "why fit carpets to bloody land rovers" and other such nonsense.
I haven't driven it yet but it does seem a lot lighter. Jim the happy defender owner |
13th Dec 2012 10:22am |
993porky Member Since: 01 May 2011 Location: sunderland Posts: 171 |
Hi just done the clutch spring and to be honest only took 5 mins,I found I could just pull rubber matting/carpet down without unscrewing the 4screws then I took old spring off and pushed clutch pedal down with 19" length of timber then popped 2 grommets in with edge of screwdriver then pushed U shaped grommet in place then long nose pliers to pop the 2 ends of spring into grommets then just pushed rubber matting/carpet up back into place and job done.
Took longer to get the tools out of shed, also just to say I ain't mechanically minded so I'm no expert but it is a simple 5 minute job. There is an improvement in the lightness but nothing special,in my opinion. Cheers paul |
31st Dec 2012 1:07pm |
abomb1969 Member Since: 23 Jul 2011 Location: Welwyn, Hertfordshire Posts: 79 |
Had a look at mine and all the bushes were already there! Only had to buy a spring off ebay, about 8 quid.
Loads better! Thanks everyone. |
1st Jan 2013 8:07pm |
hamtheman Member Since: 19 Mar 2013 Location: Louth Posts: 35 |
Completed this modification this weekend! Wow what a difference, only sorry I didn't do it earlier.
I probably could've done it in about 30 -40 minutes, but as usual was faffing around with other things while I did it, so took just over an hour! |
7th May 2013 1:30pm |
gambit Member Since: 26 Mar 2011 Location: Sussex Posts: 79 |
Have had this mod done. I say that as I had the parts just hadn't got around to fitting it, then became accustomed to the clutch so had the parts in a bag. Ian (IRB) spotted them and asked if I waned them fitted whilst my car was in for a Stage 2.
does make quie a difference, and worth doing... .... especially if it gets done along with other things |
11th May 2013 1:10pm |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 |
Did this mod today after reading the various posts on here especially from RRUK with the pics
Pedal pressure feels MUCH easier now not been for a test flight yet but i,m sure it will be a vast improvement. Well worth the effort especially as my left knee is feeling a bit fragile after driving a thousand miles in a week on hols a couple of weeks ago. If you have a Td5 and yours has,nt been done yet put it on your to do list. 2005 Td5 90 XS Steve |
18th Jul 2013 5:33pm |
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 |
What's the current parts list and where to buy from?
JohnnyD 2008 TDCi 2.4 XS CSW |
18th Jul 2013 7:48pm |
Page one of this thread, linky here<----- |
18th Jul 2013 7:57pm |
