Home > Td5 > TD5 Clutch Pedal Mod
Page 3 of 11 <123 4 ... 91011>
Well found thread.. Cool
Post #101539 22nd Nov 2011 10:17am
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
mod
you would think landrover would see there is a problem with the pedal Rolling with laughter or maybe not.
i got to do it soon ,im sure my left leg is getting big than the right Rolling with laughter
Post #103512 30th Nov 2011 2:14pm
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
Am I the only one that likes the enormously heavy clutch pedal? I think it adds to the er, character of the car.
Although it's a Censored when you've been on a long bike ride and have to get out of a tight parking space Whistle
Post #103525 30th Nov 2011 3:04pm
garyper
Australia 2003 Defender 110 Td5 SW Alpine White
Wow!!! After finding this thread I ordered the kit from Rimmer. Just put it in (without removing pedal) and a huge difference. One thing though I did lose a bit of pedal travel, has anyone else had that. The spring appears to hit the firewall.
Gary
Post #114824 13th Jan 2012 7:18am
garyper
Ha, bloody funny!!! I just found a picture of the spring in place on the net and I put it in the wrong way, no wonder it hits the firewall Smile
Ah well, at least I know how to do it now.
Post #114829 13th Jan 2012 7:58am
hossegor
Germany
would this mod also work with a Puma 2.4 ?
Post #131172 13th Mar 2012 11:43pm
CFB
I don't think the problem exists on the Puma as the pedal isn't heavy, probably a different setup so doubt it would work. Andy
Post #131222 14th Mar 2012 9:19am
hossegor
Germany
the pedal on my MY08 is so heavy its giving me knee pain.
i have to do something about it, i am thinking about getting the redbooster servo clutch but i find the price quite steep.
fitting a new spring would be a cheaper option for sure Smile
Post #131224 14th Mar 2012 9:26am
CFB
Fair enough, have a look at the back of the clutch pedal and see what type of spring is fitted, take photos' too if possible as it might be the same setup. Andy
Post #131225 14th Mar 2012 9:32am
hossegor
Germany
thanx andy, i will post some real pics tonight.
i dont know if it helps, but i have these two shots from the puma service manual...
Post #131240 14th Mar 2012 10:20am
CFB
Ok well that picture shows the spring that you fit as part of the modification to the TD5 pedal so I'm afraid this route won't work on the Puma (unless a softer spring is available). The original TD5 one is a long straight spring that is removed and replaced with the double loop one in the picture. Andy
Post #131241 14th Mar 2012 10:23am
WarPig
Would this work on a 300tdi? Do the TD5 & 300tdi share the same parts?
Post #131405 14th Mar 2012 9:39pm
alanhid
Scotland 2006 Defender 90 Td5 XS CSW Bonatti Grey
I also like my big heavy clutch..........makes me feel manly knowing Im strong enough to press it... Rolling with laughter Life is not a rehearsal!
Def 90td5 CSW xs 2006
Post #131415 14th Mar 2012 10:09pm
Gareth
Arrggghh!
I have been struggling for a couple of hours to do this mod, and just cannot get the spring to locate in the bush on the pedal.
I have tried undoing the nut on the master cylinder pushrod to get the pedal as far up as possible, but I still cannot bend the spring enough to engage it in the bush.
I think I will need to remove the pedal. One thing I cannot see is how the pedal pivot comes out? there is a threaded hole at the inboard end. Do I need a special tool or something to pull the shaft out? I cant punch it out from the brake pedal side as the steering column is in the way.
Any tips? 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #153821 5th Jul 2012 8:40pm
That's a tricky one. When I did mine I cursed at it for ages until I released the pedal push rod, and then it slotted in relatively easily. I think if you want to remove the whole pedal then it's done by undoing the six bolts that fix the M/C housing to the bulkhead under the bonnet and lifting out the whole assembly. You'll have to disconnect the brake lines though, which makes the whole task significantly more complicated.
This might sound stupid if you've been at it for while already, but have you tried putting the bush end in first and then levering in the other end with a screwdriver or mole grips? Darren
Post #153837 5th Jul 2012 10:01pm
