Home > Puma (Tdci) > NEW GEARBOX |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
Just of to Dealer again see about this gear box WISH ME WELL NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
4th Nov 2009 1:34pm |
Back from Dealer clutch needs bleeding and i'v been told all will be well.
Also i was told the dong type noise from the diff there is a bulletin on it the flange needs to have some sort of stud lock or silicon on it to stop the movement, where the prop meets the diff on a nut NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
4th Nov 2009 3:22pm |
Chui the latest on the diff dong is there is now a bulletin on it, It needs some sort off stud lock or silicon on a nut/ flang where the prop meets the diff because there is movement, say if you put it in revers and then forward you get this dong NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
4th Nov 2009 3:42pm |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 |
[/quote]Chui the latest on the diff dong is there is now a bulletin on it, It needs some sort off stud lock or silicon on a nut/ flang where the prop meets the diff because there is movement, say if you put it in revers and then forward you get this dong[/quote]
Same I had about 12 months ago - they tell me the flange was refitted with locktight - definately worked Puma 110 - gone Series III 1973 - going strong |
4th Nov 2009 4:02pm |
That sounds like it Capelandy, They also give me a full day at land rover experience NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
4th Nov 2009 4:14pm |
Thanks dgardel NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
4th Nov 2009 11:33pm |
Hi guys she is still having problems with the gearbox she went in yesterday to have the clutch bled they thought it was that but Brian the head mechanic is not convinced i'll keep you all posted NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
13th Nov 2009 10:29am |
Cannonball Member Since: 19 Jun 2009 Location: Co Laois Posts: 150 |
Interested to hear how you get on fekete. I too had a new clutch and flywheel in June. A little smoother but still not quite right. Also had new transfer box fitted last month which eliminated judder when coming to a halt. Still have clunk on power take up so please let me know if the stud lock/silicone on the propshaft/diff resulted in an improvement.
13th Nov 2009 1:44pm |
Cannonball yep as all been resolved the stud lock has eliminated the clonk, the gear box is heaven and the clutch is also 10 times better, if you have got the clonk/dong get it in and get it sorted NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
13th Nov 2009 6:26pm |
And thanks once again!
13th Nov 2009 8:40pm |
No prob's and it was stud locked on the flange on the diff NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
13th Nov 2009 9:16pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2443 |
My Landy had no clonk until 8000km. Now 21kkm. Assuming the clonk comes from the TB is there still a design problem on this unit? IŽll get a new one soon so I was thinking on adding right away some MoS based additive.
Today on the highway after driving a while I came to a stop so I shifted to neutral and and while the rig was still moving (quite slow, 5 km/h or so) I heard a quite strange rattle coming from under the floor......Like some gears did not like each other. Again I put 2nd and did the same thing (going neutral) and the rattle was gone. Any ideas? The new clutch has 4000 km from new. thanks MK Puma 110" SW ............................................................. Earth first. Other planets later |
13th Nov 2009 10:30pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5051 |
Does anyone know/have the service action - i cant find it and it would probably be the answer for me. Mike
14th Nov 2009 7:57am |
