Home > Puma (Tdci) > NEW GEARBOX
Page 3 of 3 <123
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
alantd wrote:
fekete wrote:
alantd wrote:
I think the newer clutches are much lighter. Is there any chance that it is just that?
Yes that is what it is the clutch is just lighter and the gear box is a lot better now i'v done a few miles on it
Sounds like you're just suffering from 'progress'
Yes thats what it is alantd Big Cry NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #17749 3rd Nov 2009 1:25pm
fekete
Just of to Dealer again see about this gear box WISH ME WELL Rolling with laughter Rolling with laughter NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #17825 4th Nov 2009 1:34pm
fekete
Back from Dealer clutch needs bleeding and i'v been told all will be well.
Also i was told the dong type noise from the diff there is a bulletin on it the flange needs to have some sort of stud lock or silicon on it to stop the movement, where the prop meets the diff on a nut Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #17832 4th Nov 2009 3:22pm
fekete
Chui wrote:
Fekete, can you explain the 'dong' noise you experience? I have a sound, when moving for the first time, either in reverse, or forward - it sounds like a stress 'clonk/dong'. Metal fatigue, or something of the sort. If it is a rear diff, or the half shafts, then I will get the guys to look at it. I would like to sort out everything before the warranty disappears.
Chui the latest on the diff dong is there is now a bulletin on it, It needs some sort off stud lock or silicon on a nut/ flang where the prop meets the diff because there is movement, say if you put it in revers and then forward you get this dong NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #17833 4th Nov 2009 3:42pm
CapeLandy
South Africa
[/quote]Chui the latest on the diff dong is there is now a bulletin on it, It needs some sort off stud lock or silicon on a nut/ flang where the prop meets the diff because there is movement, say if you put it in revers and then forward you get this dong[/quote]
Same I had about 12 months ago - they tell me the flange was refitted with locktight - definately worked Puma 110 - gone
Series III 1973 - going strong
Post #17835 4th Nov 2009 4:02pm
fekete
That sounds like it Capelandy, They also give me a full day at land rover experience Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #17836 4th Nov 2009 4:14pm
fekete
dgardel wrote:
MK wrote:
I googled for "a good gearbox additive......" and there were too many choices. Whistle
Whistle Whistle Whistle Whistle
FINGEAR
or
Bardahl T&D Polarplus (I used this one)
Thanks dgardel Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #17873 4th Nov 2009 11:33pm
fekete
Hi guys she is still having problems with the gearbox she went in yesterday to have the clutch bled they thought it was that but Brian the head mechanic is not convinced i'll keep you all posted NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #18282 13th Nov 2009 10:29am
Cannonball
Ireland 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Interested to hear how you get on fekete. I too had a new clutch and flywheel in June. A little smoother but still not quite right. Also had new transfer box fitted last month which eliminated judder when coming to a halt. Still have clunk on power take up so please let me know if the stud lock/silicone on the propshaft/diff resulted in an improvement.
Post #18298 13th Nov 2009 1:44pm
fekete
Cannonball yep as all been resolved the stud lock has eliminated the clonk, the gear box is heaven and the clutch is also 10 times better, if you have got the clonk/dong get it in and get it sorted Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #18316 13th Nov 2009 6:26pm
Cannonball
And thanks once again!
Post #18324 13th Nov 2009 8:40pm
fekete
No prob's and it was stud locked on the flange on the diff Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #18328 13th Nov 2009 9:16pm
MK
My Landy had no clonk until 8000km. Now 21kkm. Assuming the clonk comes from the TB is there still a design problem on this unit? IŽll get a new one soon so I was thinking on adding right away some MoS based additive.
Today on the highway after driving a while I came to a stop so I shifted to neutral and and while the rig was still moving (quite slow, 5 km/h or so) I heard a quite strange rattle coming from under the floor......Like some gears did not like each other. Again I put 2nd and did the same thing (going neutral) and the rattle was gone. Any ideas? The new clutch has 4000 km from new.
thanks
MK Puma 110" SW
Post #18329 13th Nov 2009 10:30pm
mse
Does anyone know/have the service action - i cant find it and it would probably be the answer for me. Mike
Post #18333 14th Nov 2009 7:57am
Page 3 of 3 <123
