Home > Puma (Tdci) > NEW GEARBOX
Page 2 of 3 <123>
mse
my click went with the new propshaft and second gear issue with a new selector Mike
Post #17328 27th Oct 2009 6:59pm
fekete
Hi mse, They never had the new selector in stock so they gave me the complete outfit Gearbox.
They mentioned the half shafts making the noise and it travelling down the prop but i think its the Diff Thumbs Up
I'll mention the prop to them cheers Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #17331 27th Oct 2009 7:06pm
MK
Sorry, but what do you call a "selector"? Shocked
thanks
M Puma 110" SW
Post #17332 27th Oct 2009 7:15pm
fekete
Hi MK, its a plastic thing under you're gear levers thats connected to the gearbox that helps you select 1/2/3/4/5/6 and reverse, Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #17340 27th Oct 2009 8:24pm
MK
Ok. Thanks. I also have a rough 2nd gear. But only when shifting from 1st to 2nd not from 3rd to 2nd Rolling Eyes Puma 110" SW
Post #17343 27th Oct 2009 8:29pm
fekete
MK see your dealer now so if it gets any worse you have already told them thats how mine started, don't mean to worry you but get it logged Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #17344 27th Oct 2009 8:39pm
MK
I´m going step by step. I´ll get a new TC as it clonks too much since 6000 miles. Thumbs Up
Stealer already changed the clutch assuming that is the cause of the dodgy 2nd.....I guess next is the GB time. Puma 110" SW
Post #17345 27th Oct 2009 9:01pm
fekete
Post #17349 27th Oct 2009 9:34pm
fekete
Hi All, Had gearbox replaced today mmmm ? well its no better than the last one, or it needs to bed in im not to sure though, any one had a new gearbox and it's had to bed in or am i just hoping. Also had clutch replaced as Andrews mentioned there was a noise when turning it off thanks Andrews for that. But now when pushing the clutch in it seems weak very slack any ideas Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #17508 30th Oct 2009 7:09pm
alantd
I think the newer clutches are much lighter. Is there any chance that it is just that? One that started out as a 2.4 TDCi 110 XS
Post #17707 2nd Nov 2009 10:17pm
dgardel
Italy
Problem from 1st to 2nd solved with a good gearbox additive......... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #17719 2nd Nov 2009 11:15pm
MK
I googled for "a good gearbox additive......" and there were too many choices. Whistle Puma 110" SW
Post #17721 2nd Nov 2009 11:24pm
fekete
Yes that is what it is the clutch is just lighter and the gear box is a lot better now i'v done a few miles on it NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #17731 3rd Nov 2009 8:05am
alantd
Sounds like you're just suffering from 'progress' One that started out as a 2.4 TDCi 110 XS
Post #17736 3rd Nov 2009 9:59am
dgardel
Italy
Whistle Whistle Whistle Whistle
FINGEAR
or
Bardahl T&D Polarplus (I used this one) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #17737 3rd Nov 2009 10:12am
Page 2 of 3 <123>
