Home > Puma (Tdci) > Remapping a 2.4 TDCI - What does it actually mean?
Page 2 of 8 <12345678>
BruceT
South Africa
Ok thank you.....im 99% sure that I will be doing it.
Now the off topic bit:
Im arriving the 21st after doing Calvinia and the R355 so will miss you. I have rented a house in your home town Gordons. Smile
Post #178889 25th Oct 2012 12:58pm
BruceT
South Africa
Go Beyond wrote:
It's a tough life for those Saffys .... Mr. Green
Its true ....... and on the route I have chosen to go to CT I will be doing around 200 odd kms of dirt road through the Northern Cape also..... Laughing
Post #178890 25th Oct 2012 12:59pm
Stop stop, my hearts bleeding for you Big Cry Mr. Green
Post #178891 25th Oct 2012 1:01pm
Naks
Jah boet. And now that the temperature is in the 30s, I can have the top down in the Saab Smile --
Post #178892 25th Oct 2012 1:03pm
robharvey
South Africa 2009 Defender 110 Puma 2.4 SW Alpine White
Back to the topic at hand - if you are increasing the torque by remapping, what are the negative / unintended consequences for the drivetrain? Can the gearbox, clutch, transfer box etc. manage the increase in torque, or will it reduce their lifespan?
Secondly, by remapping an engine do you increase the operating temperature / cylinder head temperatures of that engine? That would be a huge no-no in a climate like South Africa, for me at least. I do have an intercooler from Allisport on order because the standard intercoolers are not suitable for our conditions, in my opinion. It may be fine and dandy remapping in the UK, but our ambient temperatures here in summer are 30+ celsius.
My main interest lies in overlanding, therefore I don't want to compromise the vehicle's reliability. Sorry for the semi-hijack, Bruce, but I know you're have the same interests, so probably share the same conerns.
Post #178894 25th Oct 2012 1:15pm
BruceT
South Africa
Hi Rob, Definitely not a hi-jack and definitely pertinent questions. I too have the same interests.
Post #178895 25th Oct 2012 1:20pm
Alive Tuning
I've tuned many 2.4's in some very hot climates around the world.
The best case of temperature related problems have been in the northern territories of Australia, with 110's pulling very heavy trailers over hills etc. It would seem that the thermostat doesn't allow adequate amounts of coolant from the radiator, into the engine, and so the engine temp rises above safe limits, and the engine management then cuts power to stop the rise in temps from escalating. You can modify the thermostat to allow a higher bleed rate, which actually works well to control this, but maybe fitting an uprated coolant radiator could also be an option.
CHT will always be higher on a remapped car, and it's the job of the cooling system to keep them down. However, I do take care that what ever remap I make, is tailored to the climate, fuel type, and work load that is appropriate for you.
Drop me a PM if you want to discuss anything else. Wink
Post #178899 25th Oct 2012 1:43pm
BruceT
South Africa
If I dont change my driving style after a remap in theory will fuel consumption improve?
Post #178900 25th Oct 2012 1:52pm
Alive Tuning
It should, but it would depend on whether you're doing short runs where the engine and transmission is always on warm up, or long runs. Difficult to put any kind of a figure on it, but it should be better.
Another point is I will always set limiters to not exceed safe torque limits, unless I'm told otherwise! Whistle
Post #178901 25th Oct 2012 1:55pm
BruceT
South Africa
What does that even mean? (sorry a bit daft at this stuff)
Post #178902 25th Oct 2012 1:57pm
Norm4n
Alive Tuning wrote:
BruceT wrote:
Ok to try and simplify it for my understanding, if I get my 2.4 ltr mapped its going to feel like a bigger more powerful motor, ltr therefore when I tow my heavy off road caravan it is going to tow easier also?
The biggest gain you get from remapping a diesel engine, is with torque. The more torque an engine has, the 'bigger' it feels, as it's more able to deal with any additional loading. It will feel much stronger!
Please bear in mind that there are remaps, and there are remaps. There is literally millions of combinations of changes can be made, to any ECU, so it's essential you choose a company with a good reputation, and experience of tuning land rovers.
Best Regards,
Gary.
... or experience of tuning tdci fords / transits Wink
Post #178907 25th Oct 2012 2:37pm
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
I'd say that means that it won't be tuned up to the eyeballs, so all the standard drivetrain bits won't break as soon as you put your foot down.
By the same token if you have aftermarket drivetrain components, intercoolers , performance exhaust etc then I'd hazard a guess that you could have it tweaked up a bit more to gain the maximum benefit from those components and the remap.
DJ 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #178926 25th Oct 2012 4:06pm
K9F
Typical gains as an example only......Standard in blue post map green.....
BHP
TORQUE
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #178931 25th Oct 2012 4:17pm
Naks
There is no way you will be able to resist dicing with the GTIs at the robots. Ok, maybe not the GTIs, but most certainly the Cruisers!
Bruce, all things being equal, your fuel consumption will definitely improve, especially on long distance runs since the engine is now operating more effeiciently. --
Post #178939 25th Oct 2012 5:16pm
Glynparry25
I feel I can add to this through personal experience.
Here the average temperature during the summer is 35-40 degrees C. I am running an Alive map, with iTg filter, and full Alive exhaust system. NOTE: I am running standard intercooler and drivetrain.
After 20,000 miles in these conditions (after 20,000 in Germany, Austria and UK) I have had only one problem and that was where the rear diff was getting noisy. Everything else has been sweet as a nut.
With the map I tend to drive at approx 20-30% throttle and it still pulls harder than when I was on full throttle with the standard tune. For this reason the Turbo will be working less and therefore intake temperatures will be less helping reduce the engine temperatures. Even towing 2.5 tons is no hassle. The temperature has never risen above half and the vehicle has never gone into 'limp mode'
An intercooler is next on the list of things to do as I am conscious of the possible temperature issues. Especially with Roo-bar, lights and winch:
I am now consistently getting 29mpg compared to only 26mpg without the re-map. I will never look back and won't be taking it off when I do my 15,000 mile overland trip next year.
Glyn Dog :sheep:
Post #178945 25th Oct 2012 5:34pm
