Home > Puma (Tdci) > Remapping a 2.4 TDCI - What does it actually mean?
Page 4 of 8 <12345678>
Lorryman100
1ten.neuss wrote:
@BruceT
Not sure if you have seen the upgrade possibility from Bell Auto Services:
http://bellautoservices.co.uk/products/vnt...rid-turbo/
Regards,
Bernd
Just to keep things on an even keel Bernd Whistle
Alive also does the Turbo upgrade
http://www.alivetuning.com/alive-boutique/...uct_id=119
A soon to be mod on my Alive tuned Puma. Mr. Green :thumbsup:
Post #182157 4th Nov 2012 10:24pm
ZeDefender
The BAS one says "EC-1" and Alive's says "EC-4", so they're clearly not the same Wink Tell someone you love them today because life is short.
Post #182161 4th Nov 2012 10:30pm
Lorryman100
It doesn't matter what is stamped on the compressor housing, with hybrids it all depends on what has been changed internally, some examples of what changes can happen to a bog standard OEM turbo below. Depends on how much you want to spend and what power gains are achievable with a remapped engine, after all there is no point in fitting a bigger turbo without changing other aspects as the turbo lag would be huge. Wink
Porting & Polishing Turbine Housing
Ported Shroud Conversion
Fitting a Larger Compressor Wheel
Fitting a Larger Turbine Wheel
CNC Re-Profililng of Compressor Cover
Modifying the Compressor Backplate
Fitting of 360 Degree Thrust Bearing, Boost pressures of over 1 Bar, 14.7 psi.
Staggered Gap Piston Ring
Ball Bearing Conversion with Bronze Ball Bearing Carriers
Turbine Wheel Cutback
CNC Re-Profiled Turbine Housing
Fitting an Uprated Actuator
Ceramic Coating
Post #182174 4th Nov 2012 11:15pm
BruceT
South Africa
1ten.neuss wrote:
@BruceT
Regards,
Bernd
1ten.neuss.......yes ive seen all the goodies available but baby steps first!! Very Happy
Im also still under warranty so dont want to do too much yet.
Still waiting for the Atric ......... hopefully I will hear something at least this week.
Post #182181 5th Nov 2012 6:38am
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Numbers on the sides are just casting numbers 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #182196 5th Nov 2012 10:47am
ZeDefender
Ehem - I was joking (badly, as usual) - I imagine they achieve similar results Thumbs Up
On another note, I would like to fit one and run it on standard tune as well as with a remap but I guess that won't be possible... Tell someone you love them today because life is short.
Post #182202 5th Nov 2012 11:17am
Japseroony
England 2016 Defender 110 Puma 2.2 XS CSW Montalcino Red
Why not? Gas, Grass Or Ass - Nobody Rides For Free
"UNDERSTEER" ----is when you hit the fence with the front of the car.
"OVERSTEER" ------is when you hit the fence with the rear of the car.
"HORSEPOWER" ----is how fast you hit the fence.
"TORQUE" -----------is how far you take the fence with you.
Post #182210 5th Nov 2012 11:51am
Japseroony
Ceramic Coating
I agree, all of the above can and should be done but wouldn't it be good if all of the above was done by a company that was LR approved and had all the LR specs as opposed to a company that is making a copy of something Question
I think you will find that Turbo Technics are the only approved company doing this and they are only available through one tuning specialist, hi Pete Thumbs Up - all other turbos are copies with the re-manufactoring company guessing at specs and whilst they are doing a very good job, I know where my money would go Whistle Gas, Grass Or Ass - Nobody Rides For Free
Post #182211 5th Nov 2012 12:03pm
Japseroony
Glynparry25 wrote:
Japseroony wrote:
I am not knocking anyone else or trying to say one is better than the other, but this is where it all started and not only for the Puma 2.4 Thumbs Up
With that attitude, FWD automotive company was the first company to manufacture a 4x4 off-road vehicle- so does that mean Land Rovers are inferior as they weren't the first?
It is a market out there- just because someone makes the first it doesn't mean they are the best Wink Thumbs Up Shop around.
Glyn Dog Sheep
There is always someone that wants to start a war of words on here without knowing the full facts Thumbs Up but heyho each to their own Whistle Gas, Grass Or Ass - Nobody Rides For Free
Post #182213 5th Nov 2012 12:06pm
leeds
Glynparry25 wrote:
In general no...... Land Rover have gone for a maximum power of 122bhp....... so they probably de-tunned the engine to get this figure. Also remember the more power you have the less throttle/ effort you need so technically you are prolonging the life of your engine.
Glyn Dog Sheep
OK, hands up I do not understand remaps etc. Also tend to ignore such threads as they tend to get technical and above my head etc
However I am surprised a remap will prolong the life of an engine!
Is that simply due to less rpm are used? Hence less wear on cylinders and piston ring?? Or is it something else?
However would less wear be offset by higher engine temperatures due to higher fuel injection pressure/fuel being burnt more efficient?
Keep any information as simple as possible please so I can understand it Razz
Brendan
Post #182221 5th Nov 2012 12:42pm
ZeDefender
Why not?
Pete suggested a remap would have to be configured for a new turbo but maybe that's just to optimise. Tell someone you love them today because life is short.
Post #182224 5th Nov 2012 12:47pm
Japseroony
leeds wrote:
Glyn Dog Sheep
Brendan
Unlike the ebay type tunes you can buy where they often quote massive power gains, both Gary and Pete tune the vehicle within tolerences (unless asked to tune differently) so the engine will not run hotter or have more wear on its components/internals etc but equally it wont last longer so you won't prolong the life of your engine but you won't wear it out sooner Thumbs Up Gas, Grass Or Ass - Nobody Rides For Free
Post #182227 5th Nov 2012 12:58pm
Japseroony
ZeDefender wrote:
Why not?
Ahh, now I understand. If you have a hybrid turbo you can run it on a std map but in order to optimise the unit a re-map would be better. If you have a BAS box then you could run either by switching from one to the other.
I would go back to Pete and ask directly and I am sure he will be able to offer you both Thumbs Up Gas, Grass Or Ass - Nobody Rides For Free
Post #182228 5th Nov 2012 1:00pm
Braydog
Australia 2008 Defender 110 Puma 2.4 SW Alpine White
After reading all this, I'm convinced that a remap is the next upgrade on the books. I had been concerned about accelerated engine wear or drivetrain stress but sounds like its not a major concern. However here in Oz, outback touring towing a camper trailer the engine temps are always a concern. Does anyone recommend fitting an exhaust temperature gauge?
Cheers Sometimes It is better to ask for forgiveness, than to ask for permission.
Post #182253 5th Nov 2012 2:11pm
leeds
Thanks, so a decent remap will not wear engine out or prolong its life. Understood Thumbs Up
Brendan
Post #182262 5th Nov 2012 2:38pm
