Home > Puma (Tdci) > Remapping a 2.4 TDCI - What does it actually mean?
Page 5 of 8 <12345678>
BruceT
South Africa
I think it all depends mostly on thw way you drive. If you get a map and you don't start racing around and you drive it like you always do then I think it will mean the motor will last longer. (But its all relative I suppose)
Post #182263 5th Nov 2012 1:49pm
Regard
South Africa 2011 Defender 110 Puma 2.4 X-Tech LE Orkney Grey
Whats news?
When is your "new" Puma due?
Post #182265 5th Nov 2012 1:50pm
BruceT
South Africa
Regard wrote:
Whats news?
About a week or so is what I've just been told. The wait is killing me! Smile
Post #182266 5th Nov 2012 1:52pm
ZeDefender
If you would like a very good and objective reason to get a BAS remap, here's one...
Testing fuel consumption on the same "granny run" home of 5 km Munich City roads and 20 km autobahn:
Fuel consumption before remap 8.3 l/100km or 34 mpg
Fuel consumption after remap 6.9 l/100km or 41 mpg
Bear in mind I keep my speed to 80 km/h on the motorway and use whatever gear necessary to minimise consumption throughout. I know these may look like crazy figures but they are measured using Scangauge II on identical runs. Mine is a 110 SW running on Discoverer ST/Maxx 265s.
I can now drive at 100 km/h using the same fuel I used to need at 80 km/h.
I have not tested driving like a loony or with a 2 tonne trailer on the back. I am not into performance cars and would not attempt to compare handling etc. but acceleration it somewhat improved. I think the fuel consumption will be interesting to a lot of people. I just like solid figures.
Please note I am NOT making any comparison between tuners (as I have no experience). My remap just happens to be from BAS. Tell someone you love them today because life is short.
Post #182292 5th Nov 2012 3:39pm
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Are those figures taken from the ScanGauge or computed on actual measured data?
Reason I'm asking is because these seem to be extremely optimist figures while the ScanGauge will need recalibration after a remap, or else it may let you believe the fuel consumption has drop dramatically (whereas it hasn't).
Post #182295 5th Nov 2012 3:49pm
ZeDefender
What do you mean recalibration?
How does the remap change the measurements - do kilometers get shorter or litres get bigger?
I'm interested Smile Tell someone you love them today because life is short.
Post #182303 5th Nov 2012 4:10pm
o4dn
The SG needs initial calibration as stated in the user manual (ie adjust the volumes of fuel actually loaded at each fuel up).
By installing the remap, you change a lot of parameters of your engine, so the SG will need to be re-calibrated again, otherwise the values you read on your SG will be inaccurate (and way too optimistic).
All I'm saying is the only way to get an accurate mileage measurement is to measure actual distance against actual volumes, and calibrate your SG against these measures.
Post #182310 5th Nov 2012 4:27pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
I have one at the workshop that came off my 2.4 before swapping engine it was the first prototype one for development work it worked fine with and without a tune but best gains were when it was remapped Thumbs Up
Very nice bit of kit shame I've got to give it back to pete although I'm sure a new one will be sent to replace the one currently on the 3.2
Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #182312 5th Nov 2012 4:30pm
ZeDefender
Ah - I recalibrate fuel every fill up (surprisingly accurate) but haven't done it since remap. Have to fill up tonight so will double check the figures and post results.
Cheers Thumbs Up Tell someone you love them today because life is short.
Post #182313 5th Nov 2012 4:32pm
ZeDefender
Good to know Thumbs Up Tell someone you love them today because life is short.
Post #182315 5th Nov 2012 4:34pm
Japseroony
England 2016 Defender 110 Puma 2.2 XS CSW Montalcino Red
Confused here from the North East - how does a SG work? Is it user adjusted i.e. every time you fill up you tell it and you input the miles travelled Question or is it connected via OBD somehow Question
If user input then I dont see why a recalibration is needed as ZeDefender would work out how much fuel was used and over what mileage Question
Help please Thumbs Up Gas, Grass Or Ass - Nobody Rides For Free
"UNDERSTEER" ----is when you hit the fence with the front of the car.
"OVERSTEER" ------is when you hit the fence with the rear of the car.
"HORSEPOWER" ----is how fast you hit the fence.
"TORQUE" -----------is how far you take the fence with you.
Post #182371 5th Nov 2012 7:09pm
o4dn
How a ScanGauge works is a question for ScanGauge, I cannot tell. But I am convinced the values given by the SG are an approximation, not actual values, and changing the fuel map does confuse the ScanGauge...
Post #182376 5th Nov 2012 7:22pm
Japseroony
If you are posting saying this then please back up what you are saying by explaining how Exclamation Exclamation as I for one cannot work out why it would Question Gas, Grass Or Ass - Nobody Rides For Free
Post #182378 5th Nov 2012 7:26pm
ZeDefender
I just got a message from Pete that the remap doesn't change any of the fuel, speed or mileage signals from the ECU.
It is possible that the Scangauge is a bit inaccurate overall (although it was only 2 litres out when estimating my fillup this evening) BUT I now do not believe there can be a problem with the comparison.
Even if the "corrected" consumption before remap was 25 mpg, the figure after remap would be 30 mpg.
I know using Scangauge isn't as good as running two whole tanks and comparing mileage but that would be impossible to do under controlled conditions. It's the percent improvement that interests me... and others perhaps Thumbs Up
p.s. sorry Japseroony - Scangauge gets fuel level, speed and distance info from the ECU and uses them to calculate fuel consumption, fuel left in tank and calculates realtime how far you can keep driving on your current tank. You can recalibrate the fuel level each fillup by adjusting the scangauge to match the fuel you put in. It is amazingly accurate Wink Tell someone you love them today because life is short.
Post #182380 5th Nov 2012 7:27pm
o4dn
Huh? Just telling what I experienced myself. You don't have to believe me, I don't really care. Just try by yourself. Whistle
Post #182381 5th Nov 2012 7:32pm
