Home > In Car Electronics > The definitive Defender ICE thread
Page 2 of 70 <123 ... 686970>
Appleby - I have my iPod in the cubby too. Although some use the purchsed glove box too. Also a good option. Thumbs Up $W33T $0U7H3RN $UG4R
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #165206 29th Aug 2012 8:58pm
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
you lot not been and seen Mobilecentre's / Speaker 110 USW we have at the Land Rover show's have ya.... Wink Putting Dreams on Drives at JLR Solihull..
Post #165246 30th Aug 2012 12:10am
Appleby
United Kingdom 2002 Defender 90 Td5 CSW Epsom Green
got any pics we can drool over?
anyway its light and its not raining so here are some pics of my set up
Head unit
Tweeters mounted in dash
Amplifier during installation (where you can actually see it)
And with all my stuff back in the battery box
and I appologise for the grainy horrible photos (phone camera)!
Post #165324 30th Aug 2012 11:44am
Appleby - are those Alpine tweeters or a different brand? Thumbs Up $W33T $0U7H3RN $UG4R
Post #165327 30th Aug 2012 12:04pm
Appleby
The are part of the rainbow components (link in my first post in the thread) I just cut into the plastic with a stanley knife and then shaped it with a dremel. I then ring drilled the metal underneath and stuck the cups in with uhu glue.
Post #165335 30th Aug 2012 12:30pm
Appleby - Thumbs Up
Go a few issues myself that I'm interested to know peoples opinion on.
1) On the Puma for anyone who has an external amp how / in what way have you connected your direct battery power feed. I am hoping to use some kind of ring terminal on the battery positive as this is the same way my spots are wired. Interested to know what you have?
2) I have an Amp that is 500w RMS and 900w peak. I'll need 4 gauge power and earth but what AWG speaker wire will I need for that? Amp: 500w RMS 900w Peak 2Ohm load. 1x Sub 450RMS 900w Peak. Wired at 2Ohm. I am just confused which AWG size to get. I'd imagine 10 or 12 but opinions would be appreciated if possible?
Steve $W33T $0U7H3RN $UG4R
Post #165662 31st Aug 2012 9:36pm
Appleby
I've run my 550wrms sub on 12awg wire for the last 5 years in my fiesta and it has been fine. For the power wire just get a ring terminal of whatever size wiring your using and bolt it onto the clamp.
Unless you want to go all out and install one of these
http://www.caraudiodirect.co.uk/phonocar-4...minal.html
Post #165672 31st Aug 2012 10:22pm
Right I bought some 4gauge Vibe postive and negative terminals and a 2M pack of 12 gauge speaker wire Thumbs Up
Thanks Appleby for the info helped me make my mind up Thumbs Up $W33T $0U7H3RN $UG4R
Post #165725 1st Sep 2012 10:55am
mk1collector
Head unit
Does anyone know if there is a headunit that is big enough to replace the whole headunit panel on a td5 defender? I just want to get rid of the extra clipped in panel. Did Landrover have some sort of upgrade for the larger hole in the dash?
Post #165796 1st Sep 2012 5:05pm
grafty99
would the one and a half DIN sized Harmon Kardon one out of a td5 disco fit? 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #165881 2nd Sep 2012 7:49am
Killer90
Site Sponsor
how do you find them as i was going to go for the same make, i know there similar to focal so they must be good but are much cheaper arnt they Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #165891 2nd Sep 2012 9:13am
Appleby
I paid about £140 for my set. Personally I think they are fantastic speakers (only lacking a little in low end due to size, not a problem if you have a sub). I bought these as I have a set of the 165mm ones in my other car and I wouldn't hesitate to recommend them to anyone. If I had to buy any speakers again these would be my top first choice.
Post #165935 2nd Sep 2012 1:33pm
As above I agree you won't get good lows what ever you try with small size speakers but sub sorts that out but the quality is important Thumbs Up Plus with an upgraded head unit I doubt the standard LR speakers will take too much punishment compared with th rubber cone design in most aftermarket speakers. $W33T $0U7H3RN $UG4R
Post #165936 2nd Sep 2012 1:39pm
mk1collector
Do you have any pics? I did a google search but it just sent me to eBay where there were only Philips ones
Post #165939 2nd Sep 2012 2:11pm
Buzzsaw
United Kingdom 1996 Defender 90 300 Tdi HT Arles Blue
My ICE:
Uploaded with ImageShack.us
Post #165942 2nd Sep 2012 2:55pm
