![]() | Home > In Car Electronics > The definitive Defender ICE thread |
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1384 ![]() ![]() ![]() |
you lot not been and seen Mobilecentre's / Speaker 110 USW we have at the Land Rover show's have ya....
Appleby Member Since: 03 Apr 2012 Location: Bristol Posts: 74 ![]() ![]() ![]() |
got any pics we can drool over?
anyway its light and its not raining so here are some pics of my set up Head unit ![]() Click image to enlarge Tweeters mounted in dash ![]() Click image to enlarge Amplifier during installation (where you can actually see it) ![]() Click image to enlarge And with all my stuff back in the battery box ![]() Click image to enlarge and I appologise for the grainy horrible photos (phone camera)! Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20433 ![]() ![]() |
Appleby - are those Alpine tweeters or a different brand?
![]() 🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
The are part of the rainbow components (link in my first post in the thread) I just cut into the plastic with a stanley knife and then shaped it with a dremel. I then ring drilled the metal underneath and stuck the cups in with uhu glue.
Appleby -
![]() Go a few issues myself that I'm interested to know peoples opinion on. 1) On the Puma for anyone who has an external amp how / in what way have you connected your direct battery power feed. I am hoping to use some kind of ring terminal on the battery positive as this is the same way my spots are wired. Interested to know what you have? 2) I have an Amp that is 500w RMS and 900w peak. I'll need 4 gauge power and earth but what AWG speaker wire will I need for that? Amp: 500w RMS 900w Peak 2Ohm load. 1x Sub 450RMS 900w Peak. Wired at 2Ohm. I am just confused which AWG size to get. I'd imagine 10 or 12 but opinions would be appreciated if possible? Steve $W33T $0U7H3RN $UG4R 🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
I've run my 550wrms sub on 12awg wire for the last 5 years in my fiesta and it has been fine. For the power wire just get a ring terminal of whatever size wiring your using and bolt it onto the clamp.
Unless you want to go all out and install one of these http://www.caraudiodirect.co.uk/phonocar-4...minal.html |
Right I bought some 4gauge Vibe postive and negative terminals and a 2M pack of 12 gauge speaker wire
![]() Thanks Appleby for the info helped me make my mind up ![]() 🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6769 ![]() ![]() ![]() |
Does anyone know if there is a headunit that is big enough to replace the whole headunit panel on a td5 defender? I just want to get rid of the extra clipped in panel. Did Landrover have some sort of upgrade for the larger hole in the dash? Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4786 ![]() ![]() ![]() |
would the one and a half DIN sized Harmon Kardon one out of a td5 disco fit? 2002 90 Td5 Station Wagon
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
how do you find them as i was going to go for the same make, i know there similar to focal so they must be good but are much cheaper arnt they ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
I paid about £140 for my set. Personally I think they are fantastic speakers (only lacking a little in low end due to size, not a problem if you have a sub). I bought these as I have a set of the 165mm ones in my other car and I wouldn't hesitate to recommend them to anyone. If I had to buy any speakers again these would be my top first choice.
As above I agree you won't get good lows what ever you try with small size speakers but sub sorts that out but the quality is important
Do you have any pics? I did a google search but it just sent me to eBay where there were only Philips ones |
Buzzsaw Member Since: 15 Aug 2012 Location: Swindon Posts: 61 ![]() ![]() ![]() |
My ICE:
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Uploaded with ImageShack.us ![]() Click image to enlarge Uploaded with ImageShack.us ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
