Home > In Car Electronics > The definitive Defender ICE thread |
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1384 |
you lot not been and seen Mobilecentre's / Speaker 110 USW we have at the Land Rover show's have ya.... Putting Dreams on Drives at JLR Solihull..
30th Aug 2012 12:10am |
Appleby Member Since: 03 Apr 2012 Location: Bristol Posts: 74 |
got any pics we can drool over?
anyway its light and its not raining so here are some pics of my set up Head unit Click image to enlarge Tweeters mounted in dash Click image to enlarge Amplifier during installation (where you can actually see it) Click image to enlarge And with all my stuff back in the battery box Click image to enlarge and I appologise for the grainy horrible photos (phone camera)! Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
30th Aug 2012 11:44am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20447 |
Appleby - are those Alpine tweeters or a different brand? No Guts, No Glory.
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
30th Aug 2012 12:04pm |
The are part of the rainbow components (link in my first post in the thread) I just cut into the plastic with a stanley knife and then shaped it with a dremel. I then ring drilled the metal underneath and stuck the cups in with uhu glue.
30th Aug 2012 12:30pm |
Appleby -
Go a few issues myself that I'm interested to know peoples opinion on. 1) On the Puma for anyone who has an external amp how / in what way have you connected your direct battery power feed. I am hoping to use some kind of ring terminal on the battery positive as this is the same way my spots are wired. Interested to know what you have? 2) I have an Amp that is 500w RMS and 900w peak. I'll need 4 gauge power and earth but what AWG speaker wire will I need for that? Amp: 500w RMS 900w Peak 2Ohm load. 1x Sub 450RMS 900w Peak. Wired at 2Ohm. I am just confused which AWG size to get. I'd imagine 10 or 12 but opinions would be appreciated if possible? Steve No Guts, No Glory. 🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
31st Aug 2012 9:36pm |
I've run my 550wrms sub on 12awg wire for the last 5 years in my fiesta and it has been fine. For the power wire just get a ring terminal of whatever size wiring your using and bolt it onto the clamp.
Unless you want to go all out and install one of these http://www.caraudiodirect.co.uk/phonocar-4...minal.html |
31st Aug 2012 10:22pm |
Right I bought some 4gauge Vibe postive and negative terminals and a 2M pack of 12 gauge speaker wire
Thanks Appleby for the info helped me make my mind up No Guts, No Glory. 🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
1st Sep 2012 10:55am |
Does anyone know if there is a headunit that is big enough to replace the whole headunit panel on a td5 defender? I just want to get rid of the extra clipped in panel. Did Landrover have some sort of upgrade for the larger hole in the dash? Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
1st Sep 2012 5:05pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4786 |
would the one and a half DIN sized Harmon Kardon one out of a td5 disco fit? 2002 90 Td5 Station Wagon
2nd Sep 2012 7:49am |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
how do you find them as i was going to go for the same make, i know there similar to focal so they must be good but are much cheaper arnt they CSK Automotive www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
2nd Sep 2012 9:13am |
I paid about £140 for my set. Personally I think they are fantastic speakers (only lacking a little in low end due to size, not a problem if you have a sub). I bought these as I have a set of the 165mm ones in my other car and I wouldn't hesitate to recommend them to anyone. If I had to buy any speakers again these would be my top first choice.
2nd Sep 2012 1:33pm |
As above I agree you won't get good lows what ever you try with small size speakers but sub sorts that out but the quality is important Plus with an upgraded head unit I doubt the standard LR speakers will take too much punishment compared with th rubber cone design in most aftermarket speakers. No Guts, No Glory.
2nd Sep 2012 1:39pm |
Do you have any pics? I did a google search but it just sent me to eBay where there were only Philips ones |
2nd Sep 2012 2:11pm |
Buzzsaw Member Since: 15 Aug 2012 Location: Swindon Posts: 61 |
My ICE:
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Uploaded with ImageShack.us Click image to enlarge Uploaded with ImageShack.us Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
2nd Sep 2012 2:55pm |
