Home > My Defender > Mine now - 2003 TD5 90 HT |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 |
Yes, at £30+ it's more expensive than an OEM part, but not that much more than some other stainless rear trim I've seen.
Cheers Simon |
31st Aug 2012 3:20pm |
CFB Member Since: 13 Sep 2007 Location: Bradford, West Yorkshire Posts: 803 |
Just read the entire thread, wow, that really looks fabulous! Have you totted up how much you spent on it??
I love to have a project like this on the go, problem is you get hooked and in my case finish the job then sell it and start over! Andy |
31st Aug 2012 4:14pm |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2620 |
Hi RRUK
Great build and write up Having done all the hard work I would say take a break and enjoy it! Question: did I see a picture of your amp behind the passenger seat? The reason I ask is that it looked as if your ECU was on the bulk head. Do you have any better pictures of this. Many thanks Mark |
31st Aug 2012 4:40pm |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2025 |
Yes to both, will find a better picture after I've had my dinner 2016 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
31st Aug 2012 6:38pm |
I only seem to have one photo, which I think is the same one as before. If you need more detail I can take more photos over the weekend
Click image to enlarge 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
31st Aug 2012 7:20pm |
I've kept every receipt but I daren't add them up. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
31st Aug 2012 7:21pm |
Hehe, know the feeling. My receipts are kept well hidden, just in case SWMBO decided to try and add them up Andy
31st Aug 2012 7:24pm |
Hi
Yes would be grateful if you are able to to take a couple of pictures of the ECU and the area where the wiring enters the cab. Thanks in advance Mark |
31st Aug 2012 8:02pm |
Mark,
have taken some more photos for you, not much to see really. From drivers side: Click image to enlarge From Above: Click image to enlarge From passenger side: Click image to enlarge Did a few little things today, put some more carpet at the back of the drivers seat to cover the lower half of the bulkhead. Actually, that was it! 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
2nd Sep 2012 5:44pm |
SteveRat Member Since: 01 Aug 2012 Location: Chester Posts: 7 |
Great write up. I'm doing a similar thing to my 90. I've got the sound proofing down and I'm about to start on the carpet. I have a couple of questions:
Have you got any pictures of how far up the sides you went with the carpet? Did you do it in 1-2 big pieces or are the wheelarches etc seperate to the floor. Any other tips? Thanks Steve PS: stop doing stuff, its encouraging me to spend money |
4th Sep 2012 5:32pm |
Steve, Spending money like this is a good thing Its a bad thing when you start wasting money !
Ps: I see your local to me An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" |
4th Sep 2012 6:00pm |
For the bulkhead up and over I simply wrapped it and glued it. This carpet material had a clear wrapper type material on the back as it was supposed to be heated up with a heat gun. I didn't know this and thought how incredibly stiff and unworkable it was, so I peeled this layer off, leaving just the carpet and making it more malleable.
Then it was easier to wrap it over the top and glue it under the lip. With regards to the sides, the carpet ONLY covers from the top of the wheel box to underneath the MUD side panels. The floor and wheel boxes only have the thick sound proofing and then the rubber matting. Carpet on the floor wouldn't work for me as I intend to put wet dog etc in the back. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
5th Sep 2012 10:39am |
To re-site the ECU, is it a simple task to unplug the cables, pull them through the holes in the seat box (are they big enough..?) and bolt the ECU etc to the bulkhead..?
I'm alway worried about getting water (from wading) in the seat box and ECU area. Cheers Simon |
5th Sep 2012 11:36am |
Simon, I have no idea as it was not me that did this, I bought it like that.
Maybe someone with more expertise than me will be along shortly, there may even be a thread about it already if you search? 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
5th Sep 2012 12:33pm |
