![]() | Home > My Defender > Mine now - 2003 TD5 90 HT |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2025 ![]() ![]() |
Bob, I have already detailed the clutch mod in another thread, but as it adds value here I shall copy and paste it in. Green Machine also added some good help to do it, so I shall include that too. Clutch Pedal Modification
My Version: Well, nothing is ever simple is it? Despite all the great instructions from other people you can bet yours won't go the same way. ![]() Here's how I did mine. Removed rubber mat and unscrewed the metal retaining strip above the pedals. There are 3 screws on the strip and one more lower dash panel screw towards the door that needs removing so the trim strip will come loose. I had to remove the heater vent to get at one of the screws on the trim. I also have to remove the door pillar mounted interior light switch plunger, and the lower trim retaining strip, plus the door return plastic cover. I also then had to unbolt the bonnet release mechanism from the bulkhead as the cable was preventing movement of the rubber matting. That B ![]() Next, I removed the existing long spring, very easy. Then I put the bushes in place. The one on the back of the pedal has to click into place and took some right pressure to get it in, I had to use some adjustable pipe wrench pliers to squeeze it in. There was some cursing there too ![]() Next fitting the 2 side bushes. AARRRGGHHH. They were hard, but using a pair of pliers they also popped into place with the aid of some WD40. The one thing I noticed though before I started all of this was when I went to trial fit the spring into the bushes they don't fit. I know its meant to be a tight fit but it looked to me like it was never going to go in. I was tempted to ream them out a bit with a drill but decided to leave them. More on that later. I popped the spring into the bush on the back of the pedal until it clicked into place (hoping I had it the right way round) and then used a piece of wood to press the clutch in fully and wedge it against the seat box. Getting the 2 sides of the spring into the bushes wasn't that hard but I am still not convinced they are seated inside enough. Maybe they will work themselves in as time goes on, I tried to press them in further with pliers but it didn't seem to do anything. So, it's all done and I eventually managed to grapple the damned matting back into place and put back all the trim. The pedal does seem lighter, and only a proper drive will tell but it's not going anywhere right now until I have done the chassis painting and then waxoyling. Some pics for you: The parts required: ![]() Click image to enlarge Side trim and door plunger removed: ![]() Click image to enlarge Bushes in place: ![]() Click image to enlarge Finally done: ![]() Click image to enlarge 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
I also forgot to add that whilst the wheels were off the other side of the car I topped up the NS Swivel and also topped up the Diffs, although only the front needed some. Also topped up the engine oil as I was in the mood.
Filling the rear diff is a bit of a pain with one of those 1 ltr bottles with a spout top as you can't use gravity, you can't lift the bottle above horizontal due to the rear tank (on a TD5). Luckily I had just the tool for the job. Months back on eBay I bought of those oil syringes, and it was about a fiver. It's already paid for itself, suck up the EP90, squirt it in. Simple as anything. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
Thanks for the info on the stereo panel
![]() It's not the clutch pedal mod I am waiting for - damn good write up ![]() ![]() Mine makes some horrible noises when cold, fine after a few minutes. Sounds like the release bearing but if I am going to pull it apart for that it will get a new clutch at the same time. Keep up the excellent work ![]() Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
Luckily my clutch was done before I bought it, only a few hundred miles old. That's a job I wouldn't attempt myself, not enough tools or strength I reckon! 2016 D4 HSE
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 ![]() ![]() ![]() |
Any other Defender I get will be a TD5. Like yours, but the roof spots would look better round IMO. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
I'm not sure if I want to add the ubiquitous twin round driving lamps to the A-bar or whether to leave as-is.
In the depths of winter it's nice to have more main beam power I guess. Everyone seems to opt for the £50 Wipac set. Any recommendations? I don't want to spend daft money. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 654 ![]() ![]() ![]() |
I've got some unused Wipac ones I could sell you.... the cost of postage would probably be a bit on the silly side though.
Personally I really don't like the twin driving light look, hence I've been trying to get more light from just the standard units. However some LED driving lights might be quite a good, discreet answer once the price comes down a bit? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20699 ![]() ![]() |
I quite like the rectangular one's on the roof personally. It fits in the the body shape well. To my mind front A bar lights ect should be round to match the regular lights. and up top or at the rear square or rectangular. To me it just looks right.
![]() β½οΈπ’οΈβοΈπ§°πͺ |
maxw Member Since: 30 Aug 2012 Location: Derbyshire Posts: 9 ![]() |
Love the thread! You've got the inside almost perfect, just how I want mine. Keep up the good work!
Almost perfect?
What's missing?? ![]() 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
Personally I'd carpet behind the seats, and also change the rear floor mat to either checker plate or carpet depending on the uses because I feel it let's the rest down! Apart from that it's brilliant, just what I'm aiming for with my SW ![]() |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 ![]() ![]() ![]() |
Good job we're not all the same..! I always think carpet in a Defender ends up wet 'n smelly, so prefer the OEM mat. Chequer plate inside is neither original nor nice (makes it even more noisy).
So I think RRUK, you've got yours just right.. ![]() Simon |
I am not 100% happy with the rear load space floor mat.
I saw at a country/equestrian style store the other day, some very thick heavy Horse stable matting, made in rubber. Its about 15-20mm thick and you can cut it to size. It would look better and provide a little more insulation, but at £46 a sheet I am not sure. Maybe it was a little too thick as there would be a lip at the rear door threshold. I still have plenty of the carpet left and I agree, the lower bulkhead behind the seat could still be improved. I'm not sure there is a picture on the thread but behind the seats I have carpeted over the top of the bulkhead and down to the halfway rib, which sits just above my Alpine sub. I have only not done the lower half (the bit you only see if you pull the seats forward etc. The problem is that my ECU and fuse box were relocated behind the cubby by a previous owner so it makes it very awkward. Those are minor tweaks. Looking back on the start of my thread I have done 99% of what I intended to do now. Comments always welcome though and ideas I may not have considered yet. ![]() 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
I noticed that Entreq do rear trim strips with different thickness so it can accommodate floor coverings upto truck board type flooring. Cheers Simon |
