![]() | Home > Puma (Tdci) > Clutch exchange |
tatra805 Member Since: 16 Aug 2011 Location: Dolany Posts: 436 ![]() ![]() ![]() |
Naks,
the replacement clutch you have pictured seems exactly the same as the AP driveline from paddocks which was delivered to me half an hour ago. There is a difference in the number printed on the one side, i have a shorter number and a production date : 6LCGH27004A 03/12 ![]() Click image to enlarge ![]() Click image to enlarge FYI :) Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2667 ![]() ![]() ![]() |
Just got the truck back and drove the 3km from the stealer to the office in traffic.
Wow, I don't think the landy has ever felt so good - the gear changes do not clunk anymore, there is very little or no drivetrain slack. Simply amazing, even when brand new it didn't behave so well. I'm hoping this is not just my senses fooling me after being away from it for so long ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Make a fuss, make a bl%%dy big fuss until they sort it out. You can refer to my case to push for a replacement with the latest clutch. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Finally, Ford is bringing the Transit to South Africa. Maybe this will mean we can buy parts from Ford when out of warranty!
Myo Member Since: 13 May 2012 Location: Cape Town Posts: 30 ![]() ![]() ![]() |
Ha, so sent a copy of the technical bulletin to the service manager
deanbeeley Member Since: 19 Jun 2012 Location: Oldham Posts: 27 ![]() ![]() ![]() |
just had 110 xs 2008 full clutch change 89K replaced under stratstone warranty invoiced showed �1000.00
dont know if it been changed before but a different car now Deano |
67_6Cyl Member Since: 10 Feb 2010 Location: France Posts: 97 ![]() ![]() |
2007 110 SW, 120,000 kms including lots of towing with 500to 3300kg trailers, as well as lots of M-way with about 700kgs in the car.
Original clutch, no judder, rattle or other problems observed so far. Jon (where is some wood, I have to touch wood NOW!) (It's all going to go horribly wrong now I have said that all is OK!) |
astoltz Member Since: 08 Mar 2011 Location: South Africa Posts: 31 ![]() ![]() |
Technical Service Bulletin LTB00477/2012 : Released on 06 Aug 2012
Abrie https://www.defender2.net/gallery/albums/u...0Noise.pdf EDIT: The new clutch kit looks like the the same one posted by "tatra805" which is a AP driveline http://www.defender2.net/forum/post150441.html#150441 1997 Land Rover Defender 110 HT 2.8i (BMW M52) 2009 Land Rover Defender 110 HT 2.4 TDCi(Puma) |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4755 ![]() ![]() |
![]() ![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Just got back from Spain. Mine has now started to rattle like a gooden!!!!
![]() If only it had started this four months ago when I was i warrantee ![]() This one has lasted (09 truck) for 27k miles where as the 07 110 had two in 14k so there is an improvement. Do you think it is worth trying land rover to see if they will do anythig or just buy a clutch kit and do it? Boy |
Ninetenths Member Since: 26 Mar 2009 Location: Sarf Lundun Posts: 161 ![]() ![]() |
Removing the loose red lifting eye cured my "clutch rattle" issues
![]() Equally Pimped Black Pick up Truck Rollin deep |
Don't think its that as I can feel it vibrate through the transmission
thanks! As an aside, sounds like the 'new' clutch plate LR Stellenbosch put in my landy a few months ago is starting to rattle like the original... ![]() Edit: The part number for the clutch plate that went into my truck is LR012199 whereas the one in this TSB is LR029894. Are there any differences, and if so what are they? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
So finally got my 90 back, clutch chatter free!
Now the gears feel a bit sticky, no problems when changing slowly but not as quick as it was before. |
