Home > Puma (Tdci) > Clutch exchange |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2646 |
Anyone have access to the parts catalogue? We could check there? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
5th Jun 2012 8:35am |
Good to know, now there is a precedent -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
5th Jun 2012 11:29am |
robharvey Member Since: 14 Dec 2009 Location: Durban Posts: 86 |
PA = Parts Authorisation |
5th Jun 2012 12:50pm |
Stealer just called - they say the clutch is in excellent condition, no rattling, no wear on the plate, nothing out of the ordinary.
They are still going to request a new clutch 'just in case' -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
7th Jun 2012 1:27pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2440 |
make sure you do not get one of those from the faulty batch..... Puma 110" SW
7th Jun 2012 1:29pm |
Regard Member Since: 08 Dec 2011 Location: RSA Posts: 251 |
So did they take it out and inspected? If so why is nothing wrong but they will order a new clutch??? |
7th Jun 2012 1:38pm |
Because they are nearly bad since new. LR should have developed a solution by now (like a good dual mass flywheel) Puma 110" SW
7th Jun 2012 1:47pm |
They are saying they may as well try their luck to get a new clutch approved to see if this solves the rattle.
How? Is there a list of the serial number? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
7th Jun 2012 1:54pm |
tatra805 Member Since: 16 Aug 2011 Location: Dolany Posts: 436 |
been looking into this also lately
was talking with - Valeo: no puma parts, they have the exact spec for transits but don't sell it for the puma as they are aware of the trouble with the oem clutches and assume their plates would fail also. Double flywheel exists for transit with MT32 (MK, they told me it should fit, although no idea if anything ese would need changing) - Sachs: no parts - BB/AP driveline, now Raicam: OEM supplier to LR. so thats the one to go for. No info on bad batches from them. Would be useful to have some data about this. AP kits from paddocks are not britpart but raicam. In any case it looks as the britpart clutches are also made by raicam although i don't have confirmation of that. yet. |
7th Jun 2012 3:23pm |
One of the chaps here (CRJ or so) got an email from raicam about the faulty batch (lately). So, if Valeo said that means there is a design problem. Very very bad! Mine is ok now but I donīt trust the cheesy plate. Puma 110" SW ............................................................. Earth first. Other planets later |
7th Jun 2012 10:43pm |
I went to see the clutch this morning. No wear on the clutch or clutch plate, but some of the springs have minor chips and dents. As soon as I picked up the plate and shook it, the springs were rattling bigtime.
Here is a video and some pics: Click image to enlarge Click image to enlarge -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
8th Jun 2012 7:32am |
Like I mentioned, mine replaced wednesday at no charge all under waranty.
Now there is no more rattles in low gears and A LOT of the previously thought "normal drive train rattles" also vanished Like I mentioned, 3 of my springs were apparently loose/out. So I gues if yours are loose it will only be a matter of time before they fail completly. On another note, On a local forum it was said that the Ford Ranger pickup's clutch will fit and is more tuff? Think it is the T5 Ranger clutch |
8th Jun 2012 7:50am |
Valeo part number 6681A, this is off the Mazda/Ford 2.5TD pre BT50 model. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
8th Jun 2012 7:55am |
8th Jun 2012 8:08am |
