![]() | Home > Puma (Tdci) > Are swivel pins supposed to be this oily ? |
I had one exactly the same and had the seal swapped out first service. Wouldn't say it deserved a special trip to the dealers but worth mentioning if you happened by...
![]() Treat every day as if it is your last....one day you will be right!! |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
Same here ... had both mine replaced under warranty when it had its 1st year service ![]() |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 ![]() ![]() |
Doesn't look that bad to me unless it's leaking down but then I'm used to Series swivels
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
thanks guys
It can wait until July which is when first service is due ![]() |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2450 ![]() ![]() ![]() |
At least you know there is something inside the swivels Puma 110" SW
true but how much and how do you fill it when its empty ?
Its always been a mystery to me because some take EP90 and others take a one-shot grease so not sure how to maintain it ![]() |
None built in the last 15 years use EP90 .. its all grease now ![]() |
thanks Dave but how do you top it up ? I don't see a grease nipple anywhere
Actually the one shot grease comes in a sachet with the proper amount, 370 ml or so. It is a quite low viscous grease (NGLI 00), whereas "usual" grease is NGLI2.
There are 2 ways to get the old stuff out: i) disassembling the swivel or ii) heating gently the hub a bit without burning the seal and taking the lower pin out. Anyway, I think in your case maybe 1 ml is lost. There are also 2 ways to replace the seal, but I guess youŽll take it to the dealer. ![]() ............................................................. Earth first. Other planets later |
thanks MK
just a thought. I had a look at the Haynes manual - ok pre Puma models but I think the axles are the same. Would it be possible for diff oil to leak past the half shaft/CV and come through the swivel ball seal ? I changed the front diff oil recently and while I didn't overfill it I used a slightly thinner 75/90 Castrol Syntrax. |
Yes, usually oil migrates towars the swivels. Back and forth. I would not worry too much about it. Puma 110" SW ............................................................. Earth first. Other planets later |
very reassuring that. Thanks buddy !
Myo Member Since: 13 May 2012 Location: Cape Town Posts: 30 ![]() ![]() ![]() |
So I had the same problem and had the dealer change them under warranty, problem is that the problem persists, should I worry? Looks uncomfortably close to the brake discs
DarrenJ Member Since: 07 May 2012 Location: North Beds Posts: 312 ![]() ![]() ![]() |
Same here, both of mine changed at 12mths and 9k miles, you'd think they'd of got it right it now by now
