Home > Puma (Tdci) > Loss of power
Page 1 of 3 123>
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Loss of power
Shocked driving at 70mph on motorway everything was sound went to give it a bit more to overtake and there was nothing left in it....
dropped it into 5th and feathering the pedal and it just would not pic up but it never lost any speed as well ?
it felt like the turbo was not kicking in got of the motorway turned it of got me curry Mr. Green jumped back in and its fine...no light on dash to say anything is wrong .....it was raining very hard and freezing cold...could this have something to do with it ? NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #122837 9th Feb 2012 9:25pm
Lorryman100
Karlos,
take out the MAP sensor and give it a clean, also check the turbo actuator arm moves freely. Try these first and let us know the outcome Thumbs Up
Hmmm Curry, now I fancy a South Indian Garlic chille chicken curry with a garlic nan. Very Happy
Post #122838 9th Feb 2012 9:30pm
fekete
nice one Brian, will have a look in the morning Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #122839 9th Feb 2012 9:32pm
Also check your intercooler hoses, especially above your steering uj, looks and feels ok, but to be sure you need take it off.....5 min job , we've had 2 go there now.
Post #122860 9th Feb 2012 10:19pm
fekete
Thanks GREENI, will check and let you know Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #122911 10th Feb 2012 7:12am
johnszs
United Kingdom 2004 Defender 90 Td5 XS CSW Alveston Red
Egr would be my guess, take if off and give it a good clean, check that it moves freely Thumbs Up
mine did this so i removed it but as you know mines a td5 2004 TD5 Defender 90 xs station wagon
Post #123003 10th Feb 2012 1:25pm
fekete
Hi John, the EGR on mine is closed through the remap mate...i've had a look at what the other guys have said and found nothing...the truck is running fine again Question
frigging Defenders Rolling with laughter NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #123004 10th Feb 2012 1:29pm
jav-uk
England 2014 Defender 110 Puma 2.2 SW Alpine White
My Puma had a similar problem this morning.
Freezing rain on the M54, pushed the go button at about 70 and it was very sluggish.
I phoned JE and they suggest checking the MAF.
I think it could also be dodgy Morrison's diesel that was used on the last fill up or a frozen fuel line.
Will go to Shell tomorrow.
Seems okay now. Thumbs Up Paul
Pondering a New 90 Commercial
2020 Evoque
* 2014 110 SW JE Stage 2.
*2010 110 Utility. JE Stage 2.
*2007 110 SW
*2003 90 JE Stage 2.
*2000 90 SW
If its not leaking it ain't full.
Post #123009 10th Feb 2012 1:52pm
Ironically, mine lost power last night.....turned out that the intercooler hose had popped off....more substantial jubilee clips have replaced the flimsy item!
The annoying thing is fekete, you'll not know what caused it, unless it happens again! ''friggin Defenders'' indeed Mr. Green
Post #123010 10th Feb 2012 1:55pm
fekete
Greeni, will take the hose of as i've had one replaced already to se if it has been rubbing on that knuckle ..been a bit busy today so will get into it over the weekend...i drove to Rochdale last night to pick up a new generator so it was about 100 miles round trip it was chucking it down and freezing cold...it was the last 20 miles it started....as said stop to get a curry for about 10 mins then got back in it and its been fine since....as you said GREENI its a bit annoying when you don't know what the problem is in the first place....Thanks for the reply's guys Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #123022 10th Feb 2012 2:42pm
is it possible that the intercooler was blocked by freezing rain ? - just a thought
Post #123026 10th Feb 2012 2:53pm
fekete
Thumbs Up BP It must have been something like that....as its fine now Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #123027 10th Feb 2012 2:54pm
Clementine
Sweden 2008 Defender 110 Puma 2.4 CSW Auto Cairns Blue
How much fuel did you have when starting the trip? Mine 08 will have similar problems on a longer trip (+25-30min) in cold weather (below zero) and with a full tank of fuel. Problem is gone after a quick roadside stop shutting the engine off for a couple of seconds. Never happens if the tank is less than 1/2 full, if the trip is short or if the weather is warm (above zero). I start to suspect the cold causes problem with the fuel feed somehow?
Post #123133 10th Feb 2012 9:45pm
CRJ
Denmark 1991 Defender 90 200 Tdi ST Alpine White
What about the wiring to the turbo? among a lot of other things it was one thing that caused me some problems.
Regards
CRJ 88 Ser. 3 1980 -sold
Puma 130 - 08- sold
90 200tdi 1991 - sold
88 Ser. 3 1977 200 TDI
110 CC 2003
Post #123240 11th Feb 2012 3:08pm
yaho
Poland 2007 Defender 90 Puma 2.4 SW Keswick Green
May be also P1169 fault (you can check it with e.g. Scangauge). Power resumes after a while but to fix it permanently you need QO68 ECU update. Janusz
www.yahodeville.com
Post #123244 11th Feb 2012 3:29pm
Page 1 of 3 123>
