![]() | Home > Puma (Tdci) > Loss of power |
Lukey Boy Member Since: 10 Jun 2011 Location: Norwich Posts: 122 ![]() ![]() ![]() |
Thanks Lorryman - really interesting read.
Hi Brian, all correct but not about fan to run continuously. The defender have the fan viscous coupling without any electrical connection with the ECU. Some times if the viscous coupling is faulty you can see the water temp going up...... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 ![]() ![]() ![]() |
Is Brian talking about he aircon fan? I (rightly or wrongly) thought that in the event of the engine overheating this would cut in and run.
I might invest in a temperature monitor from Haydn Alarms so at least I have an idea of what’s going on and at 93 quid it’s not going to break the banks. |
The condenser fan is the only electrical operated cooling fan on the Puma and is controlled by the ECU ( Relay Cooling fan R117), my fault for not stating that as I assumed everyone knew about the viscous fan? ![]() Boy, you may be better off in purchasing a scangauge for a little more money, as it does have the ability to monitor a lot more sensors. IMHO Have a read of their site for info before you make your choice ![]() Brian. |
The aircon fan it is not "interested" by any control for the engine overtemp strategy (eg. in UK a lot of us have the Defender without aircon....).
The strategy involve the boost pressure (lowered), the fuelling massflow (lowerd) and the injection timing (retarded). Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
DG we are not talking about what the ECU employs in its strategy as I listed previously, but what tell tale there is for a failed/failing CHT sensor, harness/plug. The workshop manual also states that the electric fan will operate continuously when the CHT fails and that the ECU controls this as part of its overheating strategy. The reason the fan runs continually is because the ECU is using the stored value of 80C and does not know what the real temp is, and so as a safety runs the fan continually to assist with coolant cooling whether the coolant is cold or warm.
Fair point about non air con defenders but I have an XS, and that is what I tinker about with and submit posts about. ![]() |
Christian, you will get some movement on the vane control arm and at both ends of the control bar though the modulator arm should not move.Check that the control bar is not seized or has too much play where it attaches to the modulator or to the vane control arm. How much play do you have at each end where it attaches to the modulator/vane control arm? Turbo Modulator Harness: ![]() Click image to enlarge Turbo Modulator Harness Plug: ![]() Click image to enlarge Modulator control bar: ![]() Click image to enlarge ![]() Click image to enlarge You can see the modulator arm at the top of the control bar and the vane arm at the bottom. Brian. |
![]() ![]() ![]() ![]() IID Pro MV License |
Pics above ![]() I would just replace the MAF sensor if I had any doubts about it working as it should, as they are not serviceable and do not cost that much, about £35 IIRC. MAF sensor location: ![]() Click image to enlarge Failed MAF sensor: ![]() Click image to enlarge ![]() Click image to enlarge MAP sensor location: ![]() Click image to enlarge Brian. |
MD5 Member Since: 02 May 2011 Location: Italy Posts: 143 ![]() ![]() |
Thanks Lorryman for the useful information!
The theory is that the 2SO actually burns up completely in the burn and actively reduces the ash/carbon build up? I do agree with the poor fuel hypothesis, as a low cetane rated fuel has been proven to increase carbon build up by taking longer to ignite and burning quicker resulting in higher emissions and a rougher running, sounding engine. ![]() |
