Home > Td5 > wet floor :( |
Waldo Member Since: 18 Jul 2010 Location: Bit South of Manchester Posts: 240 |
http://www.scribd.com/doc/17833628/water-ingress-manual
Hit download on the far right once the page loads. See if you can find the problem and solution in there Will Defender 90 XS TD5 (03 Reg) |
18th Dec 2011 12:15pm |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 |
I had water dripping on my accelerator pedal too. Turns out land Rover put a few too many holes in the footwell and just covered them with tape. My tape came off and i got a leak when the water finds its way inside the bonnet and down the bulk head. Sometimes when it rained it got wet but every time i washed it with the hosepipe it managed to find its way in. I fixed it with a self adhesive puncture repair patch about 5 years ago and its still there.
Its worth looking for uncovered holes in the footwells on both sides while your at it. If you dont have air con there will be a rather large one in the passenger side!! Pete. |
18th Dec 2011 12:22pm |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
cheers zinke will go out there now and give it ago if not will download that manual and go through that thanks waldo
18th Dec 2011 1:32pm |
robpenrose Member Since: 15 Jan 2011 Location: Hampshire or Cornwall Posts: 338 |
When it rains, i get a flood in the passenger side footwell. I havent yet got round at looking for the problem yet... Current:D4 HSE
Gone: BMW Z4MC Gone: Defender TD5 90 CSW Previous: Discovery TD5 ES (Gone) |
18th Dec 2011 2:36pm |
Another couple of avenues you could go down....Did the search bit for you by entering 'carpets!'...Solution undoubtedly contained therein....Loads of wet ones, mine included, but no more! Happy reading and Happy Christmas!
http://www.defender2.net/forum/topic1334.html?highlight=carpets http://www.defender2.net/forum/topic9549.html?highlight=carpets http://www.defender2.net/forum/topic4970.html?highlight=carpets http://www.defender2.net/forum/topic4254.html?highlight=carpets http://www.defender2.net/forum/topic2920.html?highlight=carpets http://www.defender2.net/forum/topic2126.html?highlight=carpets http://www.defender2.net/forum/topic1549.html?highlight=carpets If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
18th Dec 2011 7:55pm |
cheers k9f you are the master when it comes to searching you to mate merry xmas
18th Dec 2011 8:15pm |
amondeggs Member Since: 06 Mar 2011 Location: Telford Posts: 452 |
Try having a careful look at the black sponge foam stuff that seals between the bulkhead and the windscreen. ON my car it had perished and was allowing water to leak into the footwells. I dug it out and repalced with sealant. All dry now
18th Dec 2011 11:45pm |
i think i may have sorted it the crack which i sore in the sealent were the windowscreen pillar meets the roof well when i jumped up there was more to it and the crack was pretty big, im hoping what was happining was the gutter was filling up and the water leaking into the crack down bulkhead onto the floor ive got the trusty silicon out lets see if it holds bring on the ran cheers for all the info guys and amondeggs im going to give that ago to be on the safe side cheers mate
18th Dec 2011 11:50pm |
pjb Member Since: 08 Apr 2009 Location: Sunny Oxford Posts: 1244 |
I thought this was a specific landrover design - wet footwells
I think every landrover I have had has had a leak somewhere, this one only has one on passenger floor so I thought I was doing pretty well. Impressed that many of you are leak free. I obviously need to try & find the holes 2020 P300 HSE |
19th Dec 2011 9:56am |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
water also tracks in via the rear washer pipes which come through the bulk head access by removing the n/s speaker and sorted with dum dum.
As mentioned before via the heater with water blocked in the heater box(blocked teet). 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
19th Dec 2011 11:28am |
its been raining all day here and the landy is dry inside big smiles all round
19th Dec 2011 7:29pm |
digging up a old thread but its started to leak again same spot so i decided to pull it in the back and take the hinge off and also the end dash section, after getting the torch out i could see that it was getting through the foam in between the bulkhead and window screen frame just as amondeggs suggested , im going to get some of the sealent gasket much like silicone build it up in there and finish it off with a nice top layer of black sealant
15th Jul 2012 8:11pm |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3479 |
My 2011 one wets the wife's feet above 60mph in the wet. Both found it funny that 28k buys you a damp car! 1951 80" S1 2.0
15th Jul 2012 8:14pm |
There's such a sense of accomplishment when one stops a leak - "man make fire, man stay dry" Tell someone you love them today because life is short.
But shout it at them in German because life is also terrifying and confusing... |
15th Jul 2012 8:19pm |
