Home > Td5 > wet floor :(
Page 1 of 3 123>
Killer90
Site Sponsor
wet floor :(
right i thought i had cured it but its back again if it has been raining or even when i wash the 90 i go to jump in and there is a puddle of water on the floor mat i thought it was the door seals so took them off inspeted they seem fine a pushed them up nice and tight and pinched the metal inside with pliers to make sure they stay up. i was washing the 90 today took the carpets out and the drivers carpet is drenched actually dripping off of it, from what it looks like the rain water is dripping down the bulkhead onto the accelerator pedal has anyone had this problem before and found out what it was i noticed a little crack in the sealent were the windowscreen frame meets the roof could be that Question
Post #108155 18th Dec 2011 11:09am
Waldo
http://www.scribd.com/doc/17833628/water-ingress-manual
Hit download on the far right once the page loads.
See if you can find the problem and solution in there
Will Defender 90 XS TD5 (03 Reg)
Post #108156 18th Dec 2011 11:15am
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
I had water dripping on my accelerator pedal too. Turns out land Rover put a few too many holes in the footwell and just covered them with tape. My tape came off and i got a leak when the water finds its way inside the bonnet and down the bulk head. Sometimes when it rained it got wet but every time i washed it with the hosepipe it managed to find its way in. I fixed it with a self adhesive puncture repair patch about 5 years ago and its still there.
Its worth looking for uncovered holes in the footwells on both sides while your at it. If you dont have air con there will be a rather large one in the passenger side!!
Pete.
Post #108157 18th Dec 2011 11:22am
Killer90
Site Sponsor
cheers zinke will go out there now and give it ago if not will download that manual and go through that thanks waldo Thumbs Up Thumbs Up
Post #108167 18th Dec 2011 12:32pm
robpenrose
When it rains, i get a flood in the passenger side footwell. I havent yet got round at looking for the problem yet... Current:D4 HSE
Gone: BMW Z4MC
Gone: Defender TD5 90 CSW
Previous: Discovery TD5 ES (Gone)
Post #108174 18th Dec 2011 1:36pm
K9F
Another couple of avenues you could go down....Did the search bit for you by entering 'carpets!'...Solution undoubtedly contained therein....Loads of wet ones, mine included, but no more! Thumbs Up Happy reading and Happy Christmas!
http://www.defender2.net/forum/topic1334.html?highlight=carpets
http://www.defender2.net/forum/topic9549.html?highlight=carpets
http://www.defender2.net/forum/topic4970.html?highlight=carpets
http://www.defender2.net/forum/topic4254.html?highlight=carpets
http://www.defender2.net/forum/topic2920.html?highlight=carpets
http://www.defender2.net/forum/topic2126.html?highlight=carpets
http://www.defender2.net/forum/topic1549.html?highlight=carpets If you go through life with your head in the sand....all people will see is an ar5e!!
Post #108230 18th Dec 2011 6:55pm
Killer90
Site Sponsor
cheers k9f you are the master when it comes to searching Wink you to mate merry xmas Thumbs Up
Post #108235 18th Dec 2011 7:15pm
amondeggs
United Kingdom 1999 Defender 90 Td5 HT Woodcote Green
Try having a careful look at the black sponge foam stuff that seals between the bulkhead and the windscreen. ON my car it had perished and was allowing water to leak into the footwells. I dug it out and repalced with sealant. All dry now Thumbs Up
Post #108306 18th Dec 2011 10:45pm
Killer90
Site Sponsor
i think i may have sorted it the crack which i sore in the sealent were the windowscreen pillar meets the roof well when i jumped up there was more to it and the crack was pretty big, im hoping what was happining was the gutter was filling up and the water leaking into the crack down bulkhead onto the floor ive got the trusty silicon out lets see if it holds bring on the ran Thumbs Up Thumbs Up cheers for all the info guys and amondeggs im going to give that ago to be on the safe side cheers mate
Post #108309 18th Dec 2011 10:50pm
pjb
I thought this was a specific landrover design - wet footwells
I think every landrover I have had has had a leak somewhere, this one only has one on passenger floor so I thought I was doing pretty well.
Impressed that many of you are leak free.
I obviously need to try & find the holes Embarassed 2020 P300 HSE
Post #108352 19th Dec 2011 8:56am
Grockle
water also tracks in via the rear washer pipes which come through the bulk head access by removing the n/s speaker and sorted with dum dum.
As mentioned before via the heater with water blocked in the heater box(blocked teet). 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #108381 19th Dec 2011 10:28am
Killer90
Site Sponsor
its been raining all day here and the landy is dry inside Smile Smile big smiles all round Very Happy
Post #108487 19th Dec 2011 6:29pm
Killer90
Site Sponsor
digging up a old thread but its started to leak again same spot Big Cry so i decided to pull it in the back and take the hinge off and also the end dash section, after getting the torch out i could see that it was getting through the foam in between the bulkhead and window screen frame just as amondeggs suggested Thumbs Up, im going to get some of the sealent gasket much like silicone build it up in there and finish it off with a nice top layer of black sealant Thumbs Up
Post #155783 15th Jul 2012 7:11pm
familymad
My 2011 one wets the wife's feet above 60mph in the wet. Both found it funny that 28k buys you a damp car! 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #155786 15th Jul 2012 7:14pm
ZeDefender
There's such a sense of accomplishment when one stops a leak - "man make fire, man stay dry" Laughing Tell someone you love them today because life is short.
Post #155788 15th Jul 2012 7:19pm
Page 1 of 3 123>
