Home > Tdi > TDI 200 Fuel Injector Pump
Page 10 of 10 <12345678910
cykoh85
Malaysia 1990 Defender 110 200 Tdi SW Santorini Black
Dinnu wrote:
On older axles, yes.
Hi Dinnu,
Long time no chat! My Defender has been "normal" for a while, hahaha. Now, there's some bearing-like sound coming from the gearbox in 1st gear and when I depressed the clutch before change to gear 2.
Do you happen to know the suffix for a 1991 TDI 200? My gearbox number is blurred, but I found out it could be a suffix E.
If it’s suffix E, do you know the Timken bearing numbers for each component?
Not sure if you have this information or have recorded any previously.
Thanks! Bow down
Post #1051749 14th Nov 2024 5:37pm
Dinnu
Sorry, do not know that information, but also unless you had it from new, it could have had a box change during its life.
On the Ashcroft website there is good information : https://ashcroft-transmissions.co.uk/product/lt77/
Go to the Technical page. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1051751 14th Nov 2024 6:15pm
cykoh85
Ok, thank you.
One more question: does the original engine oil dipstick come with 'L,' 'N,' and 'H' markings? I noticed that when I filled about 6.5 liters, the dipstick showed the level over 'N' and just slightly below 'H.' 'H' should mean 'High,' right?
I'm a bit confused since the manual says the capacity is 6.7-6.85 liters.
Post #1051753 14th Nov 2024 6:27pm
cykoh85
Hi bro, please see the attached picture - dipstick. this is the original from TDI200, right?
Weird thing was when I put 6.5 Liters, it showed near the line "H"
Post #1051791 15th Nov 2024 3:10am
Dinnu
AFAIK, the dipstick was the same from early 2.5 normally aspirated till the 200tdi, so that is correct.
I usually follow the dipstick. The WSM could be stating a fully emptied engine, which is not possible during an oil change. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1051793 15th Nov 2024 5:18am
cykoh85
Oh i see, Okay, noted.
So near to line H is consider normal? Or should just till the line N?
thanks.
Post #1051794 15th Nov 2024 5:42am
Dinnu
N is Normal, but I would not be too concerned if it is anywhere between the L and the H marks.
Closer to the H mark will give you more time before the oil reaches the L mark Rolling with laughter 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1051795 15th Nov 2024 6:54am
cykoh85
Ok.
hahahaha Rolling with laughter Rolling with laughter , A long way to go before reaching the L mark, and a good design for a leaking car. Laughing
Post #1051797 15th Nov 2024 7:17am
cykoh85
Hi Bro Dinnu, how are u? hope doing well.
Just want to double confirm with you—does the front axle (differential pinion oil seal) use the same part number FTC4785G? I noticed some leaks from that area (as shown in the picture).
Also, does the handbrake drum use the same part number FTC4785G? There are some droplets around the handbrake drum area as well (as shown in the picture).
Thank you.
Post #1065703 17th Apr 2025 11:21am
Dinnu
Differential pinion seal - see item 11
https://parts.jaguarlandroverclassic.com/p...and-rover/
https://www.lrworkshop.com/diagrams/land-r...0434_52598
Transfer case rear output seal - see item 7
https://www.lrworkshop.com/diagrams/land-r...ange_53758
In both cases it is advisable to check the flanges that the land where the seal runs on is not pitted or worn. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1065711 17th Apr 2025 2:08pm
cykoh85
Alright. Thank you so much Very Happy
Post #1065714 17th Apr 2025 2:52pm
