![]() | Home > Tdi > TDI 200 Fuel Injector Pump |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3529 ![]() ![]() ![]() |
Sorry, do not know that information, but also unless you had it from new, it could have had a box change during its life.
On the Ashcroft website there is good information : https://ashcroft-transmissions.co.uk/product/lt77/ Go to the Technical page. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
cykoh85 Member Since: 25 Apr 2022 Location: Selangor Posts: 143 ![]() ![]() ![]() |
Ok, thank you.
One more question: does the original engine oil dipstick come with 'L,' 'N,' and 'H' markings? I noticed that when I filled about 6.5 liters, the dipstick showed the level over 'N' and just slightly below 'H.' 'H' should mean 'High,' right? I'm a bit confused since the manual says the capacity is 6.7-6.85 liters. |
Hi bro, please see the attached picture - dipstick. this is the original from TDI200, right?
Weird thing was when I put 6.5 Liters, it showed near the line "H" ![]() Click image to enlarge |
AFAIK, the dipstick was the same from early 2.5 normally aspirated till the 200tdi, so that is correct.
I usually follow the dipstick. The WSM could be stating a fully emptied engine, which is not possible during an oil change. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Oh i see, Okay, noted.
So near to line H is consider normal? Or should just till the line N? thanks. |
N is Normal, but I would not be too concerned if it is anywhere between the L and the H marks.
Closer to the H mark will give you more time before the oil reaches the L mark ![]() 2012 90 CSW, 2.2TDCI, Santorini Black |
Ok.
hahahaha ![]() ![]() ![]() |
