Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 106 of 109 <123 ... 105106 107108109>
CMG
Germany
@ graemesmith1960 - Thanks.
But on side one of their website they show a table saying that the GenIII tool does not cover the Defender L663 2020+:
And ExpeditionParts, their dealer in Germany, says very clearly, highlighted in red color: „Gen3 does not support 2020+ cars“:
I asked them, but they presently are on holiday season shutdown. Ex D4 & D5, now Defender D250 SE 110, MY24, Eiger Grey.
Post #1055973 31st Dec 2024 10:44am
graemesmith1960
The G3 was the only one available up until earlier this year. People on this forum have been using G3's with the L663 since 2021. It works fine but some things need the G4. The 2 threads at the top of this Forum cover all that you can do with a G3 and a G4.
All you can do with a G3: https://www.defender2.net/forum/topic89347.html
Things that specifically need a G4: https://www.defender2.net/forum/topic92384.html
At the end of the day, if haven't bought one then get a G4. If you already have a G3 then just try it. Defender D350 X-Dynamic HSE 110 MY25 Carpathian Grey
Post #1055975 31st Dec 2024 11:12am
CMG
Germany
Thanks again for this info. This describes the situation as it is. All clear now. I may probably try out my colleague's G3, but I will most likely end up buying a G4.
All the best for 2025, to everybody! Ex D4 & D5, now Defender D250 SE 110, MY24, Eiger Grey.
Post #1055976 31st Dec 2024 11:17am
jtr16
Czech Republic
“Stop Driver assistance resets to High
MultiCAN-889 GSR2 EU Market Ft
Change it to Non GSR2 Country”
This worked just fine on my MY25.
Post #1055998 31st Dec 2024 3:32pm
CMG
Germany
Super. Gen3 or Gen4? Ex D4 & D5, now Defender D250 SE 110, MY24, Eiger Grey.
Post #1056005 31st Dec 2024 4:48pm
jtr16
Czech Republic
Gen4.
Post #1056006 31st Dec 2024 5:06pm
CMG
Germany
Thanks for info. Ex D4 & D5, now Defender D250 SE 110, MY24, Eiger Grey.
Post #1056007 31st Dec 2024 5:07pm
inith5
Germany
because on the sticky thread from the G4 someone asked about the exact speed... here are the settings so that everything fits
 23.5MY Defender 110 D250 HSE
Post #1056351 5th Jan 2025 9:49am
TomekW
Poland 2003 Defender 110 Td5 SW Bonatti Grey
great!
thank you
Thumbs Up 2021 Defender 90 D250
1998 TUL
1997 TUM FFR
2003 Defender 110SW Td5
1985 ExMOD 110 ST 3.9 V8
1971 Series IIa Lightweight
Post #1056493 6th Jan 2025 8:52pm
stevemfr
France
Just to clarify: we had to define a cut-off date for the G3 to G4. The G3 will do most things on an L663. But there are several things that it will not do. So if you are purchasing an IIDTool it only makes sense to purchase a G4 - especially if you would like to make CCF changes.
The G4 works on 2023's onwards. We are a small organization and don't always get around to updating the website as diligently as we should Wink
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s,
2 FL1s and a L663 on the way
Post #1056593 7th Jan 2025 7:27pm
DrRob
Question: on my old 2011 tdv8 Rangie I would reset the service interval via my GAP IID when I did 6 monthly oil changes so the ECU knew it had new oil for subsequent DPF regeneration calculations.
For an L663 with a G4 version IID I can’t see where you do that. It’s not coming up on the menus anywhere. I wonder if it’s just change the oil and filter and not reset? Seems counter intuitive.
Any thoughts ? MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung
1974 Series 3 Lightweight = "Millie"
Many Range Rovers and Land Rovers over the years 😂
1949 80" - still in family since 1975
Post #1056594 7th Jan 2025 7:32pm
Retroanaconda
G4 works well on my 2021 as well.
The service interval reset is under the instrument pack section I think. I do mine each time I change the oil too.
Post #1056603 7th Jan 2025 8:32pm
emariu
Romania
@ Retroanaconda Can you please be more specific about the section you find this reset interval in?
Post #1056605 7th Jan 2025 8:48pm
DrRob
I’ll check again but I’m sure it wasn’t showing in that menu when I checked on my 6 month old car.
Is it always there as an option irrespective of whether car shows service required on dash or not? MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung
Post #1056606 7th Jan 2025 8:52pm
DrRob
How often do you change the oil in your L663? MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung
Post #1056607 7th Jan 2025 8:55pm
