![]() | Home > My Defender > My 110 MILLIE. |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5267 ![]() ![]() |
i am spying a rear tub
![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20734 ![]() ![]() |
Millie stretched her legs well with that trip.
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 531 ![]() ![]() ![]() |
That’s such a great looking 110 Clayton! I’ve always liked the pick ups, especially with the cage. 1983 110 automatic OM606
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10958 ![]() ![]() |
Many thanks Mark ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
She sure did Steve ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
You most certainly are there Andy and there are some other parts under the tonneau cover as well ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
And probably a few tools for said new parts.
![]() ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
do i smell a few little upgrades / repairs to Millie
The rear tub will end up on Millie one day, i could not let this one go by, so collecting parts when they come about ![]() There will be an upgrade on Millie, early part of next year with a big part that you can't see in the pic ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Two or three weeks ago my N/S door handle was coming away from the door slightly when opening the door, and was getting worse the more the door was used, so on Saturday ( 28th ) i had good weather to tackle the job. Hoping for a easier fix thinking the bolt / screw just needing to be tightened up, i was wrong
![]() The bolt had not come lose, the whole that the bolt goes through on the metal part of the door frame to keep it tight had totally rusted away ![]() ![]() ![]() Click image to enlarge looking up from below ![]() Click image to enlarge I used an angle piece of aluminium for a bit more strength and cut a slot in it and then i was able to close the top part so it would not slide down, it works a treat. I didn't want to take off the handle and put a new one on as later on this year i'm going to be replacing both doors as i'm in the process of getting my spare doors done ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Good idea, you can bet if anything spins it’ll be in the most difficult access area.
LR are good at making fixes or anything like that more time consuming than expected. ![]() ⛽️🛢️⚙️🧰💪 |
Thanks Steve
![]() Yes it's always in where you can't get at it easily, the norm ![]() I think it does keep you on your toe's with getting around the " problem " ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Ingenuity is in LR owners blood by nature I think.
