Home > My Defender > My 110 MILLIE. |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5215 |
i am spying a rear tub Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
23rd Nov 2024 5:24pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20545 |
Millie stretched her legs well with that trip. KEEP CALM AND Drill ON
๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
23rd Nov 2024 5:52pm |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 493 |
Thatโs such a great looking 110 Clayton! Iโve always liked the pick ups, especially with the cage. 1983 110 automatic OM606
23rd Nov 2024 6:35pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10833 |
Many thanks Mark Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
27th Nov 2024 8:49pm |
She sure did Steve Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
27th Nov 2024 8:50pm |
You most certainly are there Andy and there are some other parts under the tonneau cover as well Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
27th Nov 2024 8:52pm |
And probably a few tools for said new parts. KEEP CALM AND Drill ON
27th Nov 2024 9:10pm |
Clayton.
27th Nov 2024 9:24pm |
do i smell a few little upgrades / repairs to Millie Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
30th Nov 2024 1:45am |
The rear tub will end up on Millie one day, i could not let this one go by, so collecting parts when they come about There will be an upgrade on Millie, early part of next year with a big part that you can't see in the pic Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
9th Dec 2024 8:37pm |
Two or three weeks ago my N/S door handle was coming away from the door slightly when opening the door, and was getting worse the more the door was used, so on Saturday ( 28th ) i had good weather to tackle the job. Hoping for a easier fix thinking the bolt / screw just needing to be tightened up, i was wrong
The bolt had not come lose, the whole that the bolt goes through on the metal part of the door frame to keep it tight had totally rusted away so i managed to undo the bolt a bit but not all the way as it was spinning on itself, i then had a moment and this is what i came up with to hold it in place, i had to slide it in from the bottom as there was no room to slide it down from the top Click image to enlarge looking up from below Click image to enlarge I used an angle piece of aluminium for a bit more strength and cut a slot in it and then i was able to close the top part so it would not slide down, it works a treat. I didn't want to take off the handle and put a new one on as later on this year i'm going to be replacing both doors as i'm in the process of getting my spare doors done Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
31st Dec 2024 9:02pm |
Good idea, you can bet if anything spins itโll be in the most difficult access area.
LR are good at making fixes or anything like that more time consuming than expected. KEEP CALM AND Drill ON ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
31st Dec 2024 10:26pm |
Thanks Steve
Yes it's always in where you can't get at it easily, the norm I think it does keep you on your toe's with getting around the " problem " Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
31st Dec 2024 10:34pm |
Ingenuity is in LR owners blood by nature I think. KEEP CALM AND Drill ON
31st Dec 2024 10:49pm |
