Home > Modifications & Maintenance (L663) > Retrofit 11.4 Pivi Display |
Santorini110v2 Member Since: 30 Jan 2024 Location: Southeast Posts: 5 |
Hi All - do you know of the G4 tool can activate the 13.1 inch screen? I don’t see the option but wondering if the 11.4 selection may work.
11th Sep 2024 1:34am |
StromC Member Since: 30 Jan 2023 Location: Rockville Posts: 13 |
MultiCAN-641 has an option for an 'Alpine 13.3 inch' screen. I believe that has to be the 13" screen from the Range Rover. The G4 tool can make the change.
I am about to test if it will work. I have a used screen from a Range Rover that I am going to try. However, it appears that it may not be that simple. It may be necessary to reflash the screen to get it to work. |
11th Sep 2024 12:17pm |
Great. Let me know how the test goes.
Do you know if reflashing the screen is possible via the G4 tool? Thinking ahead to if I purchase a new Range Rover screen. |
11th Sep 2024 2:09pm |
awktm Member Since: 19 Jun 2024 Location: Melbourne Posts: 14 |
I’ve been dealing with Patrick from Gap the last few months trying to get it programmed.. still not done but maybe getting closer!… 🙏 mine was a new 11.4
14th Sep 2024 12:31pm |
That is great! Please post the process if you get it worked out. Thanks.
14th Sep 2024 2:36pm |
Matt2104 Member Since: 28 Sep 2024 Location: Uk Posts: 1 |
Hello everyone, I am new here and I am going to do the screen upgrade with new genuine parts, just wondering if anyone had any joy with flashing the new screen with the gap 4g tool? If so was it difficult to get the correct config file?
28th Sep 2024 6:53am |
Philipp1601 Member Since: 17 Feb 2023 Location: Borken Posts: 22 |
Hello!
Is there any progress in activating and/or programming a factory new 13.1 Display with the G4? I have got an unbeatable offer for one. I do now have a 10.6 one. Any reply would be great. Thank you! Greetings Philipp --------------------------------------- MY24 Defender 110 XS-Edition D250 Stealth Mod MY07 VW Multivan T5 Sport Edition D5 MY12 Mini R55 Cooper Works MY00 MB SLK 320 R170 Designo MY21 KTM 690 SMC-R |
4th Oct 2024 5:47pm |
Lucinda's Dad Member Since: 07 Nov 2024 Location: London Posts: 1 |
After a night of drinking rum I found this on Aliexpress,
13.3" no system HD screen for Land Rover Defender 90/110/130 L663 plug and play replacement of the original 10"and 11.4" screen Usual thing of prices from 200 to 600 pounds, depending on the seller. Came with the fitting plate and a nifty little extension for the Facra connector. no need to code. Resolution slightly off but works nicely. Only niggle is screen will only show when ignition properly on |
7th Nov 2024 7:38pm |
