![]() | Home > Puma (Tdci) > New Owner Issue |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 935 ![]() ![]() ![]() |
Once it’s sorted, at least you’ve had a heap of parts changed, for free. 2008 2.4 110 Utility Station Wagon XS.
Birdy Member Since: 07 Oct 2011 Location: Côte d'Azur Posts: 883 ![]() ![]() ![]() |
"To date the dealer has replaced Intercooler , MAF , MAP, all boost charge pipes , turbo , turbo actuator , EGR cleaned and new seals"
That sounds like the dealer who dignosed my vehicle's failure to fire up, as a faulty starter motor and replaced it. No difference, it was the battery! But at least mine put the old starter motor back and didn't charge me... Peter |
If it worked ok with the MAF removed, then it may be worth a look at the wiring to that sensor. Where it enters the plug it can suffer from stress damage:
![]() Click image to enlarge I noticed that problem on my old 110 and repaired it with a pre-wired plug from the site shop, which you can read all about here: https://www.defender2.net/forum/post853238.html#853238 Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3069 ![]() ![]() |
The O/P has gone quiet.
l wonder if his Defender was finally sorted. l hope so, it sounds like the dealer has replaced everything. |
Ashbyandy Member Since: 17 Dec 2015 Location: Leicestershire Posts: 226 ![]() ![]() ![]() |
As LandRoverAnorak has stated, and I’ve also mentioned before. We had a customer, that had the same persistent problem. I noticed that the wiring can actually touch the back of the Puma bonnet, which also probably causes the insulation of the wiring to break. A new pre-wired plug, and a cable tie, to pull it down away from the bonnet, and he had no more problems 👍 |
Six weeks later and still silence from the O/P.
l wonder if he rejected the vehicle and bought something else. |
Daphne Member Since: 22 Nov 2023 Location: Kent Posts: 26 ![]() ![]() ![]() |
It’ll be a blocked oil cooler, the oil gets hot and the sensor cuts the power this doesn’t throw a mil light and doesn’t read on the water thermostat so temp looks normal.
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 928 ![]() ![]() ![]() |
It would appear that the roller coaster experience of Land Rover ownership wasn't for him? Jim |
I know his pain my 2.2 has been total
Silverspeed Member Since: 07 Jul 2024 Location: Leicestershire Posts: 14 ![]() ![]() ![]() |
Thanks for all the comments to my issues . Sorry I’ve been silent for sometime due to holidays and then my parents both became ill so the Defender issues took a back seat . So where are we now - regrettably and frustratingly the car is still not with me . The vehicle has been sent to Bishops 4x4 in Peterborough by the selling dealer . They initially thought electrical but all the tests and checks show this not to be the case . The car is not logging any codes or throwing the MIL ( although it initially did when the car arrived - showed boost fault ) . They have done all the fuel supply incl breathers etc , tested fuel rail and injectors . Also checked EGR cooler as known to rot from inside out , accelerator potentiometer , turbo actuator , the known issue with the rev counter sending spurious messages to ECU , all the earths . They are going to replace the temp sensor on the block again ( supplying dealer replaced this with MAP and MAF although they feel the erratic nature of it going in to fault possibly points to ECU . They have one ready to fit but want to do this as last resort as they cannot send it back once attached to the vehicle . Since June I’ve had the car for 8 days in total - frustrating to say the least . The one thing no one has checked is the oil temp sensor but wouldn’t this throw a fault code ? I’ve asked for it back by end of the month - I’m meeting friends at Chatsworth and they don’t believe I actually own one ! Let’s see what next couple of weeks bring - almost forgotten what she looks like !
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 588 ![]() ![]() ![]() |
Thanks will pass info on .
If turbo is not in good condition, thé engine will loose power and rpm
