Home > Puma (Tdci) > New Owner Issue
Page 2 of 2 <12
Silverspeed
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Corris Grey
Further update on my issue . To date the dealer has replaced Intercooler , MAF , MAP, all boost charge pipes , turbo , turbo actuator , EGR cleaned and new seals , three pressure tests all ok and still has an issue with it going in to limp mode . We thought it was the MAF sensor as when this was removed it ran on a number of test drives without going in to limp mode hence it being replaced. New one fitted and still issues . The dealer is now thinking ( as others have suggested ) electrical . Will be great to get it back - I’ve only had the vehicle 7 days since I bought it in May .
Post #1042031 5th Aug 2024 11:59pm
BrickBox
Once it’s sorted, at least you’ve had a heap of parts changed, for free. 2008 2.4 110 Utility Station Wagon XS.
Post #1042047 6th Aug 2024 9:40am
Birdy
France 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
"To date the dealer has replaced Intercooler , MAF , MAP, all boost charge pipes , turbo , turbo actuator , EGR cleaned and new seals"
That sounds like the dealer who dignosed my vehicle's failure to fire up, as a faulty starter motor and replaced it. No difference, it was the battery! But at least mine put the old starter motor back and didn't charge me...
Peter
Post #1042059 6th Aug 2024 12:49pm
If it worked ok with the MAF removed, then it may be worth a look at the wiring to that sensor. Where it enters the plug it can suffer from stress damage:
I noticed that problem on my old 110 and repaired it with a pre-wired plug from the site shop, which you can read all about here:
https://www.defender2.net/forum/post853238.html#853238 Darren
Post #1042061 6th Aug 2024 1:46pm
lightning
The O/P has gone quiet.
l wonder if his Defender was finally sorted. l hope so, it sounds like the dealer has replaced everything.
Post #1042671 13th Aug 2024 5:14pm
Ashbyandy
England 2015 Defender 110 Puma 2.2 Adventure Phoenix Orange
As LandRoverAnorak has stated, and I’ve also mentioned before. We had a customer, that had the same persistent problem. I noticed that the wiring can actually touch the back of the Puma bonnet, which also probably causes the insulation of the wiring to break. A new pre-wired plug, and a cable tie, to pull it down away from the bonnet, and he had no more problems 👍
Post #1042675 13th Aug 2024 7:04pm
Page 2 of 2 <12
