Home > Technical > Help with 200tdi clutch creaking |
mini Anaconda Member Since: 23 Aug 2016 Location: Thames Valley Posts: 771 |
Thanks guys. I'll update once it has been looked at by the garage. BORG - Bucks & Oxon 4x4 Response Group
17th Aug 2024 9:26pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3342 |
The heavy duty one on its own will last longer, but might not last as much as the original one but greased well on assembly. Note that I would suggest high temperature grease, so it does not melt on your first run. When my fork failed, which is quite normal even with a standard good clutch, the only immediate available fork was the standard one. So I welded on a 6mm flat bar, that I kind or bored to fit better over the ball socket. After many many years of clutch use, I had refitted the fork as did not show signs of wear or imminent failure. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
18th Aug 2024 6:17am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20115 |
Castrol high temp lithium is good NEVER SURRENDER! ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
18th Aug 2024 1:51pm |
