Home > Technical > Help with 200tdi clutch creaking
Page 2 of 2 <12
Retroanaconda
The pivot point for the clutch release arm wears over time, particularly if not greased when assembled. Same goes for the pins that the release bearing shoes sit on. The noise may be the result of this.
Post #1043061 17th Aug 2024 6:50pm
mini Anaconda
Thanks guys. I'll update once it has been looked at by the garage. BORG - Bucks & Oxon 4x4 Response Group
Post #1043070 17th Aug 2024 9:26pm
Dinnu
mini Anaconda wrote:
Mine already has a heavy duty one. Which if that is problem, doesn't inspire much confidence! Rolling Eyes
The heavy duty one on its own will last longer, but might not last as much as the original one but greased well on assembly. Note that I would suggest high temperature grease, so it does not melt on your first run.
When my fork failed, which is quite normal even with a standard good clutch, the only immediate available fork was the standard one. So I welded on a 6mm flat bar, that I kind or bored to fit better over the ball socket. After many many years of clutch use, I had refitted the fork as did not show signs of wear or imminent failure. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1043079 18th Aug 2024 6:17am
Castrol high temp lithium is good Thumbs Up WeWillWin๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿ‡บ๐Ÿ‡ธ
โ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #1043100 18th Aug 2024 1:51pm
Mark0
United States
I bet you just need to pack some grease into the box where the other end of that clutch pedal connects under bonnet. There should be six screws to remove the top plate of the box.
Will take a pic when I get home of where I packed mine with grease last year and it solved a similar sound (although mine was a bit more โ€œsqueakyโ€ sounding) ๐Ÿ˜€.
[edit] Blue outline is where I packed grease:
Doubt itโ€™s the fork, mine just punched through and it had no noise at all prior to failing.
[edit] Yellow is where the fork pushed through, currently waiting on that and a few other parts ๐Ÿ™ƒ
Post #1049502 23rd Oct 2024 2:10am
Page 2 of 2 <12
