Home > In Car Electronics > Re-doing my electrical setup, Weird fuse question
cecilkift
United States
Hey there, I'm a new owner of a 1985 Defender 110.
Slowing getting used to working on a car, having a blast.
As I'm studying my electrical setup I noticed that I have two electrical lines that just end in a fuse. That seems very weird to me. I'm no mechanic or electrician but as far as I understand electrical systems it does not serve any purpose. Am I wrong? The one in the picture can just be removed, but I have another that comes from the indicator lights that end in the same way.
Cheers Cecil
Post #1041967 5th Aug 2024 2:39pm
Is this the pic you meant to post from your gallery you uploaded:
? Chillin In The Backwoods🇬🇧🇺🇸
Post #1041969 5th Aug 2024 2:43pm
cecilkift
United States
yes, that's it!
Post #1041970 5th Aug 2024 2:44pm
Presumably clamped to the battery positive post..
It is likely to be a “tail” on a supply out for a supply that’s been removed that was fused in-line.
What they’ve done is instead of removing the entire supply line, they’ve disconnected it just after the fuse, so the fused spur is kept in place which could be used again or just taken away. Chillin In The Backwoods🇬🇧🇺🇸
Post #1041972 5th Aug 2024 2:51pm
cecilkift
United States
Great, thank you for the help. I'm definitely removing it since I'm doing a full clean-up here.
Post #1041973 5th Aug 2024 2:53pm
Yeah, if you are not going to use it, it makes sense to take it away.
I think they just left it in place in case it was going to be used again, perhaps so it doesn’t get lost or something like that.
Thumbs Up Chillin In The Backwoods🇬🇧🇺🇸
Post #1041979 5th Aug 2024 3:28pm
