![]() | Home > In Car Electronics > Re-doing my electrical setup, Weird fuse question |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20612 ![]() ![]() |
Is this the pic you meant to post from your gallery you uploaded:
![]() Click image to enlarge ? Chillin In The Backwoods🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
cecilkift Member Since: 19 Jul 2024 Location: California Posts: 6 ![]() ![]() |
yes, that's it!
Presumably clamped to the battery positive post..
It is likely to be a “tail” on a supply out for a supply that’s been removed that was fused in-line. What they’ve done is instead of removing the entire supply line, they’ve disconnected it just after the fuse, so the fused spur is kept in place which could be used again or just taken away. Chillin In The Backwoods🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
Great, thank you for the help. I'm definitely removing it since I'm doing a full clean-up here.
Yeah, if you are not going to use it, it makes sense to take it away.
I think they just left it in place in case it was going to be used again, perhaps so it doesn’t get lost or something like that. ![]() ⛽️🛢️⚙️🧰💪 |
