Home > Modifications & Maintenance (L663) > Retrofit 11.4 Pivi Display |
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 170 |
have you modified the ccf file? as already written, if you install a brand new 11.4 screen, it will not work, because it must be programmed. the 10 screen, when you go back to the original ccf it must work for sure, otherwise there is a problem with the connector or the fuses, I advise you to take a tester and test the presence of power and ground on the connector. When carrying out work on the electrical system, always disconnect the car battery.
Marco |
25th Jul 2024 6:22am |
Click image to enlarge in my case, used 11.4 screen, everything worked perfectly. Thanks Clark |
25th Jul 2024 6:35am |
Dannymm Member Since: 28 Jun 2024 Location: Wiltshire Posts: 18 |
Can you post a photo of the cable you have made? |
25th Jul 2024 7:54am |
hi, now I've closed everything, and I don't have any photos. However, I followed the published wiring diagram and used the connectors recommended by Clark. If you want, send me a photo of your cables and I'll check if they're ok.
25th Jul 2024 7:58am |
I was asking deekay for a photo of his cable so we could maybe check it for him.
The only issue I had with my custom cable is I had to swap the CAN bus wires even though I checked they were correct so many times! |
25th Jul 2024 8:01am |
on the diagram it is easy to confuse the colors of the can wires, because they are crossed
25th Jul 2024 8:08am |
deekay Member Since: 24 Jul 2024 Location: NY Posts: 11 |
I was able to get the 10.1" screen working again last night after doing a service reset with the GAP tool, double locking, and waiting a bit before retrying (possibly the most important step).
Now this morning, I wired up the 11.4" screen again, repeated the steps above, and still a blank screen so far. This is what the wiring looks like. Perhaps I have something mixed up? Click image to enlarge [/img] |
25th Jul 2024 1:39pm |
It looks correct, have you tried swapping the can wires? (pins 3 and 9) of the grey connector
25th Jul 2024 2:16pm |
I'll give it a shot right now.
25th Jul 2024 2:30pm |
The can wires are reversed the gray green goes on the connector at pin 3. |
25th Jul 2024 4:33pm |
Violet green wire on pin 3, (not gray green…sorry)
25th Jul 2024 5:43pm |
Ok I swapped the pins for the two CAN wires (at the small black connector, not the grey connector; that should be the same, right?). I started the car, did a Pivi reset, did a service reset, and then double locked the car. I'll check it in an hour or so to see if that did the trick.
One thing I noticed before stepping out of the car was that "circuit open" fault was recorded. Not sure if this is just a transient fault that can be ignored, or if it means the harness and/or display are broken? Click image to enlarge Click image to enlarge |
25th Jul 2024 5:46pm |
hi Deekay, sorry, I was in the car and I misread the connector, everything was correct, I was wrong, so the layout of the can pins was right, now it's wrong. open circuit means that 12 volt power is not arriving, so two possibilities: 1 the 12 volt pin does not fit well in the connector, 2 a fuse has blown. test with a tester if you have power and ground.
25th Jul 2024 5:55pm |
No worries. I just swapped the pins back and I'll see if the open circuit fault comes back. Fuses looked fine.
25th Jul 2024 6:11pm |
