Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
BadgerWaz Member Since: 15 Jul 2024 Location: Linconshire Posts: 56 |
Question:
Is there a list that either currently is, or could be: made a sticky of all the activations made by users and the options they selected when turning on disabled features? |
15th Jul 2024 10:44pm |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1396 |
https://www.defender2.net/forum/topic89347.html
https://www.defender2.net/forum/topic92384.html Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
15th Jul 2024 11:31pm |
pjeski Member Since: 25 Jul 2023 Location: Michigan Posts: 101 |
(Sigh)
https://www.defender2.net/forum/topic92384.html https://www.defender2.net/forum/topic89347.html Hairy beat me to it. |
15th Jul 2024 11:35pm |
Here's a video that I did to show how easy it is to enable the 007 Screen, it's the same process for all other activations but you will need a G4 tools to do the likes of ACC. The G4 tool does do a lot more changes as it is going through the process than the G3 but the options are to click continue to keep the update going. (it just takes longer) ?si=UDzfHo5IJQ_whYYV Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
15th Jul 2024 11:37pm |
Perfect thank you both very much. I had searched the site posts before registering too so I’ve obviously been looking for the wrong tag lines.Exactly what I was looking for It would be the G4 I’d be ordering, it’s on eBay for 550 which is cheaper than buying from GAP directly. |
16th Jul 2024 7:15am |
Does anyone know: Do gap offer any discount codes on the forum for buying the G4 direct from them?
16th Jul 2024 11:10am |
I’ll let you know if it can be done as soon as my G4 arrives. This is the main reason I’m buying it as to avoid using an aftermarket tuner/remapper. If the G4 activates Land Rovers own software they can’t argue the warranty is void. |
16th Jul 2024 11:13am |
defending Member Since: 07 Jul 2024 Location: Edinburgh Posts: 5 |
Anyone managed to fix the park assist start button grey out issue ?
Got it all showing up and searching for space but can't select start Wonder if it is blocked for UK models Last edited by defending on 17th Jul 2024 11:29pm. Edited 1 time in total |
17th Jul 2024 11:27pm |
No they don't but if you get in touch with Duckworth's at Market Rasen and mention the forum they will do you a good price Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
17th Jul 2024 11:28pm |
Cheers, I'd checked the faq's on gaps' website and they don't offer voucher codes, but I did find a seller that has the G4 in stock so at least I won't be paying full import tax fees.
I've got one on its way to me for £606 (£6 delivery) from an established LR stockist. I'll be trawling through the menus looking for the D250-D300 option first and foremost to see if this actually changes boost/fuelling etc. etc. |
18th Jul 2024 9:14am |
Whoever got park assist working, can you please email your ccf so we can do a comparison to find the missing part of this puzzle
I’ve noticed couple of faults when enabling park assist (with grey out start) Click image to enlarge Click image to enlarge |
18th Jul 2024 11:14pm |
It seems the IID tool cannot in fact be used for upgrading the power. There is no power upgrade file that can be loaded to it, so a trip to a remapper for a custom tune seems the only option (which puts me off). I have emailed/spoken with four mappers so far who do not offer files for the Defender, even LR won't offer the factory upgrade which is infuriating. Bummer. If anyone knows otherwise please let me know. A stage-1 remap is about as simple as it gets for a mild torque/power increase, but I was hoping for the factory software to be loaded for obvious reasons. |
19th Jul 2024 12:53pm |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 |
BadgerWaz I know LR-Retrofits & Royles Performance offer power upgrades using LR files they have both advertised D250-D300, not sure if the D350 upgrade is available yet. 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
20th Jul 2024 8:21am |
I'll give Royles' a call on monday and see if I can buy the file for remote loading thanks. (Done this with my AMG using a hand-held before with an MSL file.)
Right, I have a 2023 D250 and I've loaded most of the list on the sticky to my ecu via my G4 IID. So far partially so good. Some of the numbers have changed on the G4 but are pretty much the next one. E.g. 177 may be 176. My experience after the first ccf changes: The rear tailgate pops open when I press my keyfob which is useful for my dogs. The dynamic mode is available and works, but I do not have any red illumination as others have mentioned. When I press the Terrain Response button it's a bit hit-and-miss and sometimes just flashes and won't let me choose comfort/dynamic/eco etc. without restarting the engine. The configure option for Terrain Response isn't working for me at all, is this because I'm on coil springs? The front fog lights remain on when high-beam is on. The seatbelt warning light doesn't sound anymore if I drive without a belt on across our field. I had a factory towbar installed so had towing options already, but I've enabled the additional features from the sticky so I'll see if anything changes when the trailer is back on the car. What I was looking forward to was the auto cruise control, after changing the ccf to activate this my steering wheel then illuminated with the controls for setting radar distance, but to my total dismay my cruise control no longer works at all I'll spend some time looking through the long list and see what I can find/alter to get my cruise control back/TR working. If anyone has experienced this and has a quick fix please share. I have reset the pivi and left the car for around an hour locked up and sat still. **What I would say to anyone else that's keen to buy an IID and have a go, is make sure you have plenty of battery charge and a suitable backup. I had a fully charged battery, tethered to an auxillary battery that was also fully charged, connected to a 14.4amps rapid charger, and the energy still drained quickly enough from the Defender battery to throw a warning up on the dash. This was whilst simply scrolling through the list and not during file uploading/writing. I set one of our other cars running and connected jump leads, but the battery warning came back so I closed the app/IID down and removed it so I could run the Defender. Maybe only make small quick changes between journeys, I sat and loaded everything all at once. |
21st Jul 2024 12:03am |
