Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
Dannymm Member Since: 28 Jun 2024 Location: Wiltshire Posts: 17 |
You can disable the fake engine noises played through the stereo or even choose different versions with these two settings:
Next Generation Power Train Sound Quality (NGPTSQ) MultiCAN-584 NextGenPwrTrnSQ PTSQ NLI MultiCAN-585 ActSndDesignPwrlvl NGPTSQ I have upgraded the factory amp and speakers and wanted to turn all off the artificial sounds that affect the sound quality. |
21st Jul 2024 11:35am |
BadgerWaz Member Since: 15 Jul 2024 Location: Linconshire Posts: 56 |
Good man, I'll try these today. I have 580 & 809 selected already so I'll add the 712/753 thanks. I have the diesel so no fake engine noises. Have you managed to turn off the adblue? **edit*** still no cruise control, TR still not configuring For my ACC I have enabled trhe following and without success: EOCD023 cruise control fitted -Adaptive Cruise Control, Stop & Go & then Adaptive Cruise Control, Stop & Go, Brake Limit 2, With ACC To CC Toggling MC503 intel cruise control MC580 PT Cruise fitment MC670 fwd traffic detection MC683 intel emergency braking (to CAEB fitted) MC694 cam forward alert MC719 intelligent emergency braking MC794 front radars fitted MC809 ACC stop gap setting None of this has made any difference at all to gaining ACC or CC of any kind. The speed limiter works and that is all. I'm reverting back to the factory selection so I at least have basic cruise control back in the car. I've spent an entire morning faffing and driving back/forth testing the ACC. I've also changed: MC580 generic power output to: standard engine high MC599 engine power from 249/365 to 300/700 but this appears to have done zero. I have a GPS logger so can measure acceleration etc. but it feels like it is the same factory D250 power. I've spent a full day on this now, uploading changes at least eight times and trying them. This ACC is driving me nuts If I emailed GAP would they have insight on what combination I should try for ACC or is it still at the 'try and see' stage of development? |
21st Jul 2024 12:26pm |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 411 |
Can you confirm the settings you used ? , or just disabled ? Mine are now: MultiCAN-584 NextGenPwrTrnSQ PTSQ NLI MultiCAN-585 ActSndDesignPwrlvl NGPTSQ Thanks in advance No Mud flaps for my 90.! ----------------------------------------- P300 S MY21 on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
21st Jul 2024 7:23pm |
Yes set both to disabled
21st Jul 2024 7:37pm |
I think it is standard on all Defenders to have the sensor behind the front Land Rover badge on the grille - I think that is used for the adaptive cruise control. Worth checking you have that fitted. |
21st Jul 2024 7:49pm |
DefenderMidlands Member Since: 08 Mar 2023 Location: West Midlands Posts: 223 |
Do you have the latest firmware version on the gap tool? Might be worth plugging into a computer and checking MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar
21st Jul 2024 8:00pm |
pjeski Member Since: 25 Jul 2023 Location: Michigan Posts: 103 |
"Disabled" or "Not Fitted" or "Not Supported"? Disabled doesn't seem to be a choice on my Defender: MultiCAN-584 NextGenPwrTrnSQ Not Supported Not Fitted PTSQ NLI PTSQ MID PTSQ HIGH PTSQ PREM PTSQ Hybrid Error MultiCAN-585 ActSndDesignPwrlvl Not Supported Not Fitted NGPTSQ PTSQ NLI PTSQ Lo PTSQ Hi PTSQ Hybrid PTSQ V8 Cylinder Deactivation Error |
Sorry yes both 'Not fitted'
21st Jul 2024 8:03pm |
sasa Member Since: 05 Mar 2024 Location: ceska lipa Posts: 42 |
yes, and i also think there are 2 types of logos, i guess powerfuluk pointed it out in some video (he also gave part numbers, one is opaque)
21st Jul 2024 8:33pm |
I removed the front upper grill and the sensor is there yeah, as far as I'm aware they all have this fitted for auto.emergency braking. The G4 I bought last week came with the most recent firmware as I registered it with GAP and checked for updates, and see I have the latest build. I'm either missing a simple setting, or my sensor is a duffer that doesn't want to play. I can get the gap/distance function illuminated on my steering wheel, but even after leaving the car stood overnight the settings still wouldn't take. I've also reset the pivi screen many times. I have the option in the pivi to set my preferred ACC gap, but the actual ACC or normal CC for that matter won't work. I have to return to factory settings to enable my normal CC. I expect it's something simple, but I've sat and read through the 1000 ccf options more than once, and have tried eight various configurations to no avail so I've almost 'wasted' a full day of tinkering for no reward other than a learning experience. |
21st Jul 2024 10:01pm |
kenl Member Since: 11 Jul 2022 Location: bunvegas Posts: 27 |
I would suggest changing the values that others have proven work, then just forget about it. Often it can take days before the settings actually work. MY23.5 SE Defender
21st Jul 2024 11:32pm |
I have done it you look at what parameters I’ve set/activated.
It seems strange that everything else I’ve programmed has worked instantly after locking/unlocking the car, same as when I’ve had any other vehicle coded by a tuner so I’m not sure how leaving the car for days would all of a sudden activate something?? Surely that can’t be right? Or is the LR unique to this concept? |
22nd Jul 2024 6:17am |
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 158 |
HI,
I advise you not to superficially modify all these CCF parameters, they interact with many systems of the car, not only acc, to enable ACC, as written in the guide in this place, you ONLY have to change: MultiCAN-580 PTCruiseFitment: ACC with Queue Assist fitted MultiCAN-712 ACC Lead Car Distance Display: Fitted MultiCAN-809 ACC Stop Gap Setting: Fitted. only these parameters, the others are not necessary in most defenders. the problem with the configurable TR can arise from these too many modifications. As for the procedures, you need a power supply of at least 40 amps, (when writing consumes around 35 amps), a diagnostic stabilized power supply that sets the voltage between 13.8 and 14.0 volts, other techniques are risky on the voltage stability. |
22nd Jul 2024 8:30am |
mohd Member Since: 13 Jun 2024 Location: uae Posts: 9 |
hello, can someone please share with me the original CCF of a V8 or an X 2023/2024
22nd Jul 2024 9:40am |
