Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
dakluck Member Since: 20 Jan 2023 Location: San Diego Posts: 8 |
I've been going mad on this one. I've tried replacing the headlamp ECUs, every coding you can imagine, and am about to tear into these things. I cannot for the life of me figure out what combination would enable the halo functionality of these new lights. I even spoke to the GAP team and we did a compare between my vehicle and the donor vehicle. Even with exact CCF settings I still cannot get them to go on. I've heard people mention a headlamp ECU flash, but haven't really found anyone that could actually describe that process and how it could be done. My replacement pair are KZ3 043 Premiums thankfully, but I'm almost certain at this point that I either need to buy JLR Pathfinder + TOPIx to do a headlamp ECU flash, rip into them and replace LED module, or scrap it entirely and go back to my basic lights. Thread below with more details if anyone is interested! https://landroverforums.com/forum/2020-def...on-115791/ |
1st May 2024 11:37pm |
malibu Member Since: 11 Sep 2023 Location: Melbourne Posts: 49 |
Sorry to change the topic slightly. I would like to retrofit TPMS. I believe I need to purchase a module that goes into the roof, above the light panel. But before I pull the light panel out, I was wondering if the GAP G4 shows the ECU module. Could somebody please with TPMS, open their Ecu Infos menu and see if it shows the TPMS module? Thanks in advance
2nd May 2024 10:31pm |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 421 |
For convience the Llams height controller is making that possible with just 2 turns left on the selector knob. https://www.defender2.net/forum/post963767.html Click image to enlarge No Mud flaps for my 90.! ----------------------------------------- P300 S MY21 on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
3rd May 2024 12:54am |
northeye Member Since: 18 Sep 2022 Location: Tokyo Posts: 11 |
I believe that the volume control key will work on only MY24 or above vehicles. On my friend's MY24 worked, but mine MY23.5 didn't. |
3rd May 2024 6:50am |
Looneyfitter Member Since: 03 Mar 2024 Location: Liverpool Posts: 30 |
Only if you have the larger screen
3rd May 2024 6:53am |
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 162 |
HI, here's to you, the gap recognizes tpms ecu, which will be appropriately configured on the ccf file. Be careful if you buy a new ecu, you will need pathfinder or topix cloud to load the appropriate software, if you buy used it should work fine, but it will be stored with its donor vin. Marco Click image to enlarge |
3rd May 2024 7:57pm |
Bobbobbobbob Member Since: 04 Jul 2023 Location: Brum Posts: 20 |
Feeling proud of myself that I can potentially make a contribution after all the help I've got from this site.
Driver Assistance is now remembering last setting for me. Just as a disclaimer I have no real idea what I'm doing with this stuff but it seems to work. MultiCAN-889 GSR2 EU Market Ft GSR2 Country Changed it to Non GSR2 Country. The regulations which insist on this are called GSR2 and there are a few other related settings. |
4th May 2024 8:48am |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1413 |
Great work Bobbobbobbob If this works for other people I'll add it to the sticky post. Cheers Ian
-------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
4th May 2024 5:46pm |
On my CCF the G4 does not support this number
MultiCAN-889 GSR2 EU Market Ft Not Supported Some more info about this subject: https://www.autocar.co.uk/car-news/technology/gsr2 No Mud flaps for my 90.! ----------------------------------------- P300 S MY21 on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
4th May 2024 8:07pm |
pjeski Member Since: 25 Jul 2023 Location: Michigan Posts: 106 |
Sometimes “not supported” doesn’t mean not supported.
4th May 2024 8:34pm |
Johan6504 Member Since: 13 Jul 2020 Location: Partille Posts: 13 |
I was hoping to be able to do the same, but as far as I know it's not possible ☹️ |
5th May 2024 5:10am |
@mmbanf, thank you. What other implications would I have having a module with an incorrect VIN number?
5th May 2024 6:15am |
HI,
no implications, at least on the European market... I did the rerofit of the matrix headlights, I have a different vin number on the headlight ecu, no errors, no malfunctions. there is also a way to write the original vin but you have to make a connection with enet obd, via svs company. Marco |
5th May 2024 6:55am |
HI ,
we are trying to solve a problem with retrofitting premium LED headlights on US specification vehicles, User with defender equipped with premium LED headlights, can you please post a photo of the ecu configuration of headlights A and B? Example in the photo. Thanks in advance for sharing. Marco Click image to enlarge |
5th May 2024 9:49am |
