Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 87 of 109 <123 ... 868788 ... 107108109>
dakluck
Re: US Spec Defender w/Premium Headlamps
Cometboy wrote:
dakluck wrote:
Does anyone have a stock CCF file for a US spec Defender with the premium headlights? Preferably closer to the 2020 model year, but I’ll take anything right now to get these headlamps coded correctly!!
hey there. don't know if anyone ever answered you.
i am in NJ and have been fiddling with the G4 and the different headlight units.
In the US market the Premium LED is actually called Matrix Led AFS123/IHB in the CCF using G4.
These are the units that are labeled as KZ3 04S.
if you have the KZ3 05S variant then you have the "Pixel LED AFS123/IHB...
Hope this helps...
be careful of people selling "Matrix LED" for NAS Spec as they are just KZ3 04S "Premium LED" and not the KZ3 05S "Matrix LED" ...
Good Luck
I've been going mad on this one. I've tried replacing the headlamp ECUs, every coding you can imagine, and am about to tear into these things. I cannot for the life of me figure out what combination would enable the halo functionality of these new lights.
I even spoke to the GAP team and we did a compare between my vehicle and the donor vehicle. Even with exact CCF settings I still cannot get them to go on. I've heard people mention a headlamp ECU flash, but haven't really found anyone that could actually describe that process and how it could be done.
My replacement pair are KZ3 043 Premiums thankfully, but I'm almost certain at this point that I either need to buy JLR Pathfinder + TOPIx to do a headlamp ECU flash, rip into them and replace LED module, or scrap it entirely and go back to my basic lights. Thread below with more details if anyone is interested!
https://landroverforums.com/forum/2020-def...on-115791/
Post #1033560 1st May 2024 11:37pm
jordjdw87
Can anyone with a g4 IID confirm that you can set the three vehicle heights independently? I’d like to lower the access mode without lowering the standard ride height. This is to help my dogs getting in/out the back of the car!
Apologies this is a dupe of a separate post - just wondering if there’s a clear yes/no to using the tool
Post #1033577 2nd May 2024 7:53am
malibu
Australia
Sorry to change the topic slightly. I would like to retrofit TPMS. I believe I need to purchase a module that goes into the roof, above the light panel. But before I pull the light panel out, I was wondering if the GAP G4 shows the ECU module. Could somebody please with TPMS, open their Ecu Infos menu and see if it shows the TPMS module? Thanks in advance
Post #1033670 2nd May 2024 10:31pm
Defendit..
Netherlands
jordjdw87 wrote:
Can anyone with a g4 IID confirm that you can set the three vehicle heights independently? I’d like to lower the access mode without lowering the standard ride height. This is to help my dogs getting in/out the back of the car! Apologies this is a dupe of a separate post - just wondering if there’s a clear yes/no to using the tool
For convience the Llams height controller is making that possible with just 2 turns left on the selector knob.
https://www.defender2.net/forum/post963767.html
 No Mud flaps for my 90.!
P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #1033678 3rd May 2024 12:54am
northeye
Japan
hthagood wrote:
Hairy Dan wrote:
These are the main changes from the G3, most of the MultiCAN numbers were there in the latest G3 firmware but they were all down as not supported, they now have options Thumbs Up
MultiCAN-882 Sidebar Controls
Sidebar Controls with DSC + VC Drawer AND VC Bar on 4x4i
MultiCAN-892 SideBar Climate
Climate Icon on Side Bar Available - FICP Replacement
MultiCAN-894 Volume Soft Keys
Audio Volume Soft Keys pattern
MultiCAN-896 ReCircle Soft Button
Soft Button Fitted with timed and latched logic
MultiCAN-897 Max AC Soft Button
Soft Button Fitted
MultiCAN-897 Max Defrost Soft Button
Soft Button Fitted
MultiCAN-897 AC OnOff Soft Button
Soft Button Fitted
MultiCAN-897 Auto Climate Soft Button
Front AUTO Climate Soft Button Fitted
MultiCAN-898 Front Htd Screen Soft Button
Soft Button Fitted
MultiCAN-898 Read Htd Screen Soft Button
Soft Button Fitted
Anyone been able to get the soft volume control to function? All I get is a readout of “0” and no volume control. It will show mute status? Thanks!
I believe that the volume control key will work on only MY24 or above vehicles.
On my friend's MY24 worked, but mine MY23.5 didn't. Crying or Very sad
Post #1033686 3rd May 2024 6:50am
Looneyfitter
Only if you have the larger screen
Post #1033687 3rd May 2024 6:53am
mmbanf
Italy
HI,
here's to you,
the gap recognizes tpms ecu, which will be appropriately configured on the ccf file.
Be careful if you buy a new ecu, you will need pathfinder or topix cloud to load the appropriate software, if you buy used it should work fine, but it will be stored with its donor vin.
Marco
Post #1033735 3rd May 2024 7:57pm
Bobbobbobbob
Feeling proud of myself that I can potentially make a contribution after all the help I've got from this site.
Driver Assistance is now remembering last setting for me.
Just as a disclaimer I have no real idea what I'm doing with this stuff but it seems to work.
MultiCAN-889 GSR2 EU Market Ft
GSR2 Country
Changed it to Non GSR2 Country.
The regulations which insist on this are called GSR2 and there are a few other related settings.
Post #1033785 4th May 2024 8:48am
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
Great work Bobbobbobbob Thumbs Up If this works for other people I'll add it to the sticky post. Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1033814 4th May 2024 5:46pm
Defendit..
Netherlands
On my CCF the G4 does not support this number
Not Supported
Some more info about this subject:
https://www.autocar.co.uk/car-news/technology/gsr2 No Mud flaps for my 90.!
Post #1033821 4th May 2024 8:07pm
pjeski
United States
Sometimes “not supported” doesn’t mean not supported.
Post #1033825 4th May 2024 8:34pm
Johan6504
Sweden
I was hoping to be able to do the same, but as far as I know it's not possible ☹️
Post #1033838 5th May 2024 5:10am
malibu
Australia
@mmbanf, thank you. What other implications would I have having a module with an incorrect VIN number?
Post #1033840 5th May 2024 6:15am
mmbanf
Italy
HI,
no implications, at least on the European market...
I did the rerofit of the matrix headlights, I have a different vin number on the headlight ecu, no errors, no malfunctions.
there is also a way to write the original vin but you have to make a connection with enet obd, via svs company.
Marco
Post #1033842 5th May 2024 6:55am
mmbanf
Italy
Retrofit led premium US
HI ,
we are trying to solve a problem with retrofitting premium LED headlights on US specification vehicles,
User with defender equipped with premium LED headlights, can you please post a photo of the ecu configuration of headlights A and B?
Example in the photo.
Thanks in advance for sharing.
Marco
Post #1033853 5th May 2024 9:49am
