![]() | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
carltb Member Since: 06 Oct 2023 Location: Sweden Posts: 63 ![]() ![]() ![]() |
Also interested in this. I thought it was just the hybrid that does this. Everytime I open the drivers door and get out the car turns off. Extremely annoying. 2025 Defender 130 V8 (DOA, new one coming) 2025 Defender 90 D250 (wifes) 2024 Defender 110 p400e HSE (sold) 2015 Defender 110 Double cab 2004 Defender 90 Td5 |
Johan6504 Member Since: 13 Jul 2020 Location: Partille Posts: 13 ![]() ![]() |
I got the G4 last week and successfully activated Park Assist, Global open/close, Dynamic mode and Configurable terrain mode.
However, cant find any info about TR2 Auto. Has anyone successfully activated TERRAIN RESPONSE® 2 AUTO? Any list of CCF changes to try? |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2729 ![]() ![]() |
If the start/stop is deactivated (via the switch) the car will keep running when you get out. |
fst_drvr Member Since: 08 Apr 2024 Location: Los Angeles, CA Posts: 5 ![]() ![]() |
Also interested in this, has anyone had success in unlocking TR2? Can't seem to find any CCF info on this. |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1442 ![]() ![]() ![]() |
You can try these settings for Auto Terrain Response, ATPC and configurable terrain response, let me know how you get on. You will need a G4 for this.
EUCD-129 Terrain Response Fitment Auto Terrain Response/JDO, Dynamic EUCD-213 Eco Data (Driver Information Display) Function enabled (Display Information level 4) MultiCAN-476 ATPC HDC and LSPC MultiCAN-497 IntelEmerBrkingCUIEB IEB fitted MultiCAN-736 Config TR Fitment Off Road Configuration MultiCAN-754 Auto TR Prog Mode Fitted MultiCAN-755 Config TR Mode Available for selection with timeout MultiCAN-778 Ter Auto Select In FCPB Rotary used for selection within touch screen MultiCAN-788 Drive Mode Disc Strat Use legacy strategy to discover drive mode fitment (repair) MultiCAN-789 Drive Mode Order AlI Terrain Vehicle Including Auto Order MultiCAN-797 Ter CT Select In FCPB Rotary used for selection within touch screen With the G3 this used to cause an emergency brake fault, so this should work with the g4, if it doesn't work you can chage all your settings back again ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Wow thanks for the speedy reply Ian, will give this a try this weekend with my G4 Gap tool.
If you email a copy of your original ccf to yourself via the app it will be easy to compare your settings should you need to revert or if you haven't made any other changes you can revert back to your original as built ccf
![]() ?si=f2TncojqjVkFASNN Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Great! Will try later today ![]() |
Hi
New to the world of CCF files and GAP iiD, so curious to learn s much as possible. Browsing through the CCF file I found one entry showing the gas tank size. It is listed as 50L and I am pretty sure the P400e comes with a 90L tank. Should I edit the data or just leave it? The car seems to work just fine... If it aint broken dont fix it, right ![]() |
Dammitdeano Member Since: 07 Nov 2023 Location: Brisbane Posts: 13 ![]() ![]() |
I can’t seem to select dynamic mode.
I have the config screen working and I can see dynamic mode on the dash when I press TR and rotate the dial but not on PiviPro. However I cannot select it. I noted that on the most recent CCF settings for TR2, auto and config TR, ATPC EUCD-129 Terrain Response Fitment Auto Terrain Response/JDO, Dynamic But in the dynamic mode EUCD-129 Terrain Response Fitment, Set to "Auto Terrain Response Dynamic & Configurable Dynamic Mode" Which should I use to achieve both dynamic TR selection and the auto/config TR? Last edited by Dammitdeano on 18th Apr 2024 8:03am. Edited 1 time in total |
Doublepost 2025 Defender 130 V8 (DOA, new one coming)
2025 Defender 90 D250 (wifes) 2024 Defender 110 p400e HSE (sold) 2015 Defender 110 Double cab 2004 Defender 90 Td5 Last edited by carltb on 18th Apr 2024 7:56am. Edited 1 time in total |
I noticed that as well and thought about it. Change it and let me know what happens 😉 Can I ask what range your car says you have? Mine never says more than 500km which is a bit odd considering the 90L tank. 2025 Defender 130 V8 (DOA, new one coming) 2025 Defender 90 D250 (wifes) 2024 Defender 110 p400e HSE (sold) 2015 Defender 110 Double cab 2004 Defender 90 Td5 |
Hi
The range varies depending on how much city driving I have done. On long journeys it can show up to 70 km. But I have always felt it to be on the low side. Maybe I'll just change it and see what happens, what is the worst than can happen ![]() |
That particular setting probably doesn't apply to your Defender so best to leave well alone, The CCF file covers a lot of different vehicles so there will be numerous setting not applicable to the Defender.
