Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 75 of 108 <123 ... 747576 ... 106107108>
OVRLANDR
United States
There are definitely a lot more CCF’s viewable with the G4 unit. As of yet, I have not tried to change anything. Will know more after the weekend.
Post #1026413 29th Feb 2024 9:04pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
These are the main changes from the G3, most of the MultiCAN numbers were there in the latest G3 firmware but they were all down as not supported, they now have options Thumbs Up
MultiCAN-882 Sidebar Controls
Sidebar Controls with DSC + VC Drawer AND VC Bar on 4x4i
MultiCAN-892 SideBar Climate
Climate Icon on Side Bar Available - FICP Replacement
MultiCAN-894 Volume Soft Keys
Audio Volume Soft Keys pattern
MultiCAN-896 ReCircle Soft Button
Soft Button Fitted with timed and latched logic
MultiCAN-897 Max AC Soft Button
Soft Button Fitted
MultiCAN-897 Max Defrost Soft Button
Soft Button Fitted
MultiCAN-897 AC OnOff Soft Button
Soft Button Fitted
MultiCAN-897 Auto Climate Soft Button
Front AUTO Climate Soft Button Fitted
MultiCAN-898 Front Htd Screen Soft Button
Soft Button Fitted
MultiCAN-898 Read Htd Screen Soft Button
Soft Button Fitted
 Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1026416 29th Feb 2024 9:31pm
roccobarocco
Germany
That's splendid news, can't wait any longer for my G4 arriving as soon as possible. Very Happy
Again great support by GAP, they are doing a great job!
Cheers Greg
Post #1026419 29th Feb 2024 9:48pm
Dammitdeano
Australia
I can’t follow which option I need to select from the G4 exchange web page to exchange my 3 month old G3 in Australia. I’ve emailed support to figure it out.
Post #1026455 1st Mar 2024 10:15am
Santorini110v2
United States
New G4
Just received my G4. Has anyone successfully activated Adaptive Cruise Control? If so, would you mind sharing the modules and selections?
Post #1026549 2nd Mar 2024 2:39am
matt4x4
Germany
ACC with G4 works
Hi folks.
I got my exchanged G4 two days ago and was able to activate ACC on my MY23.5 D250 XS
EUCD-023 Cruise Control
Standard: Without cruise control
Changed to: Adaptive Cruise Control Stop & Go
MultiCAN-580 PTCruiseFitment
Standard: Normal cruise fitted
Changed to: ACC with Queue Assist fitted
MultiCAN-809 ACC Stop Gap Setting
Standard: Not fitted
Change to: Fitted
MultiCAN-712 ACC Lead Car Dist Disp
Standard: Fitted
Changed to: Fitted
* this was already set on my car
I also set these parameters, cause I read about it somewhere.
But what does this really it do?
MultiCAN-753 Adaptive Prog Mode
Changed to: Fitted
And I found other settings, which are listed as unsupported,
but sounded intresting to ACC.
Perhaps some defaults to set in the PIVI – but did not find anything yet
?MultiCAN-712 MultiCAN-712 ACC Stop Gap Select
?Standard: Not supported
?Changed to: Fitted
?MultiCAN-712 ACC Accel Profile Select
?Changed to: Fitted
In the "activation session" the tool was not able to clear 2 faults, which popped up with DADC.
But after letting the car sit alone for lunchtime, I was able to clear the faults with the tool
ACC now works fine ....
Great work GAP-Team Thumbs Up
Post #1026559 2nd Mar 2024 9:38am
lightning
l've had a reply from GAP
The unit has to be sent back to them
in Canada for the upgrade replacement scheme.
l assume most people know this already but just in case anyone doesn't.
Can anyone tell me the procedure to activate the "more accurate speedometer" using G4 tool as in the U.K. it's set to read 3-4 mph high.
Using my G3 tool
lf l just change it to +1 mph it doesn't change the cruise control so that still reads high. lf you change the other settings to reset the cruise control, the vehicle comes up with an error on the screen and defaults to 2wd with various safety systems inoperative
Post #1026563 2nd Mar 2024 10:11am
pjeski
United States
The procedure should be the same, and the G4 should reset the DADC.
Post #1026566 2nd Mar 2024 10:54am
Santorini110v2
United States
Re: ACC with G4 works
Thumbs Up ACC works like a charm. Thank you!
What else is now available with the G4? Self park and ATPC2?
matt4x4 wrote:
Hi folks.
Change to: Fitted
Standard: Fitted
Changed to: Fitted
Changed to: Fitted
?Changed to: Fitted
?Changed to: Fitted
Post #1026635 3rd Mar 2024 3:12am
DefenderMidlands
All terrain progress control
***THROWS UP BRAKE ERROR WITH GAP iid3 TOOL but should work on iid4 tool as need to clear DADC which iid4 tool can do***
MultiCAN-476 ATPC
Orignal: HDC
Changed to : HDC and LSPC
Possible lock up and 15 min wait required, no Pivi rese needed MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar
Post #1026637 3rd Mar 2024 6:12am
DefenderMidlands
Possible park assist settings although not sure many people have made it works, possibly some people abroad but maybe not in the uk. Uk cars may be missing something hardware wise
Activate Park Assist
***THROWS UP BRAKE ERROR WITH GAP IID 3 TOOL BIT MAY WORK WITH IID4 TOOL***
EUCD-059 Parking Assistance
Standard: Without Parking Assistance
Change to: PDC (Front, Rear) - Parking (Parallel, Exit)
EUCD-099 Park Assist Camera
Standard: Without Park Assist Camera
Change to: With Park Assist Camera
EUCD-140 Pdcautoactivationmenu
Change to: With PDC Auto Activation menu
MultiCAN-469 PDCAutoActivation
Standard: Not Supported
Change to: Default OFF configurable
MultiCAN-500 PDCBtnFCIM
Change to: Fitted
MultiCAN-602 PDC
Standard: PDC not fitted
Change to: 10 Channel fitted ( Park Assist)
MultiCAN-786 Park Assist
Standard: Not Fitted
Change to: Full Auto VarD (Fully automated park assist with automated steering breaking accelaration and gears) MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar
Post #1026638 3rd Mar 2024 6:16am
Ratledge
United States 2016 Defender 90 300 Tdi SW Auto Stornoway Grey
Supposedly, but apparently self-parking is not certain? Maybe just for UK, but "the jury is still out"...
Mine came with ACC, maybe required? The one report above says they're likely missing hardware. We'll see shortly.
My guess is that they dumbed down Defenders that are delivered in GB, maybe just "commercial" spec?
Post #1026778 4th Mar 2024 11:20am
nebc100
Luxembourg
Self Park doesn't work on my 2024 110.
Same as other people have had... all menus seem to work, but parking won't start.
Note: I am not in the UK.
Post #1026782 4th Mar 2024 11:52am
Ratledge
Hmmm... Didn't spec mine out: I'm a six months old D90S MY23.5 (P300).
Post #1026784 4th Mar 2024 11:58am
johnlad
How are you people sending your unit back. I’ve struggling to find a commodity code for the item and if you put gift and value of €5 as advised then you can’t insure it for it’s value.
How are you guys doing it?
Post #1026832 4th Mar 2024 6:45pm
