Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 76 of 110 <123 ... 757677 ... 108109110>
Retroanaconda
There’s a commodity code for ‘vehicle diagnostic device’
Post #1026836 4th Mar 2024 7:58pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
There is a setting for Automotive diagnostic device and if you put it down as warranty return, value £5. Did Patrick ask you to put it down as a gift? Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1026891 5th Mar 2024 12:25am
dakluck
US Spec Defender w/Premium Headlamps
Does anyone have a stock CCF file for a US spec Defender with the premium headlights? Preferably closer to the 2020 model year, but I’ll take anything right now to get these headlamps coded correctly!!
Post #1026893 5th Mar 2024 3:53am
pjeski
United States
aquascape wrote:
MultiCAN-682 DynamicLiteMode Set to Available for Selection Without Timeout.
I think this setting allows you to select dynamic Mode from the touchscreen OR the rotary control
I didn’t set dynamiclitemode and everything works fine, touch and knob. I haven’t heard that dynamiclitemode does anything. Lack of it has certainly not hurt my dynamic or TR activations.
Post #1027231 7th Mar 2024 10:26pm
Bobbobbobbob
Got my defender today, anyone know when the G4 is going on general sale?
Post #1027377 9th Mar 2024 1:11pm
inith5
Germany
nebc100 wrote:
Self Park doesn't work on my 2024 110.
Same as other people have had... all menus seem to work, but parking won't start.
Note: I am not in the UK.
Same for me. Everything is there except the start button is grayed out and cannot be pressed.
Activated today with the G4. 23.5MY Defender 110 D250 HSE
Post #1027415 9th Mar 2024 7:16pm
coda0
United States
Same for me. Everything looks correct except the "Start" Buttons is greyed. out.
Post #1027434 9th Mar 2024 10:07pm
pjeski
United States
When I activated configurable terrain response, it took a full day for the choice to show up on the PIVI screen, even after two PIVI resets, though it would show up on the IDD. Scrolling too it chose comfort. The next day, all working as should be. Maybe the park assis is the same way.
Post #1027436 9th Mar 2024 10:26pm
Nicofender
Germany
Someone tried to make a D300 out of a D200 already?
Post #1027442 10th Mar 2024 1:14am
chpsk8
United States
Very Happy
Delete - duplicate post
Cow
Post #1027503 10th Mar 2024 5:00pm
chpsk8
United States
I tried parking assist yesterday. No luck.
I have the steering wheel on the PIVI.
I can select the steering wheel and it brings me to a new screen where it is actively scanning for parking spots.
It asks me to stop and select a spot.
I can toggle between parallel and bay parking.
I can select the parking spot.
I cannot select start
I did have luck with ATPC. It takes two pushes on the button to activate, but it does work.
I was able to program ACC. I did have to let it sit to clear errors, but it works without error now.
Anyone have any other codes to try on the parking function?
I have a 2023.5 110 P300
Post #1027504 10th Mar 2024 5:00pm
pjeski
United States
It's supposed to.
Post #1027511 10th Mar 2024 5:33pm
DefenderMidlands
Two presses of the hill decent control BUTTON is correct to activate ATPC MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar
Post #1027512 10th Mar 2024 5:33pm
dsstephens
United States
<double> 2020 SE First Edition
2004 Disco2
1986 110 V8
1971 Series IIa 88”
Post #1027684 11th Mar 2024 9:00pm
dsstephens
United States
Got the G4 this weekend and activated. Connected and read. noticed 3 things
1) engine is running, but it is flashing red letters at the top indicating <ign> (need to verify exact wording).
2) when connected, it threw a "emergency braking not allowed" error without any intervention
3) tried changing 007 setting as a simple one and the ACC as not so simple; update failed. tried restoring backup, update failed (even though it hadn't successfully written first). now it throws ATPC and HDC not available errors. Will let it sit and go out and try it all again. open to any suggestions. 2020 SE First Edition
2004 Disco2
1986 110 V8
1971 Series IIa 88”
Post #1027685 11th Mar 2024 9:01pm
