Home > Puma (Tdci) > Output shaft failure, Forum Survey
Page 29 of 33 <123 ... 282930 313233>
LR90XS2011
transfer box not quite in gear? DEFENDER 90 TDCI XS,
Post #941504 7th Feb 2022 10:01pm
natyeo
United Kingdom 2014 Defender 90 Puma 2.2 HT Santorini Black
Fair point , was in middle of busy junction so wasn't really checked over just towed away and garage only 2 miles away, since fitted Ashcroft ATB , replaced worn rear hub ends (Slight wear), 'A' frame ball joint as it had a little lift and a few suspension bushes.
Tempting fate but seems fine now at 129023 and a few trailer miles will post when and if it gives up. 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb
2012 2.2 tdci 110 Utility
1993 110 CSW Warn M8000 , Scorpain winch bumper , 2" lift , Roamerdive overdrive, on going
1971 Hybird 200tdi, 2 x truetracs,Extrem winch bumper, M8000, GKN overdrive & Coils 2" lift, Glynn Lewis cranked rear trail arms
1971 Series 3 88, Perkins 4203,M8000,SATs,O/D,
Post #941696 8th Feb 2022 7:04pm
KevP
France
1, vehicle year of manufacture - 2013
2, engine type 2.4
3, is the Defender still running with the original output shaft? Yes
4. Current Milage 51000 miles
Post #999859 13th Jul 2023 6:34am
schuee
1. Vehicle year of manufacture 2011
2. Engine type 2.4
3. Is the Defender still running with the original output shaft? (Y/N) Y
4. Current mileage on the original shaft, 128,937 MY2011 110 XS USW
Post #1002500 1st Aug 2023 11:54am
Glen-I
Having just fitted an Ashcroft output shaft, here are my statistics.
1, vehicle year of manufacture - 2014
2, engine type 2.4 or 2.2, - 2.2
3, is the Defender still running with the original output shaft? (Y/N) - N
4, vehicle mileage - Shaft not failed, but changed due to hearing an occasional feint knock when taking up drive at 32000 miles
5, Has an Ashcroft modified part has been fitted? (Y/N) - Y
6, vehicle mileage at the second failure, or mileage if still running. Literally just fitted the new shaft
The noise was minimal, but the difference after fitting the new shaft, has made an massive improvement with drivetrain slack (didn't realise how much I had).
Post #1016665 28th Nov 2023 10:14pm
MK
So 32,000 miles. Is it a 110"? Puma 110" SW
Post #1016670 28th Nov 2023 10:49pm
Ianh
Looking at his prior posts and pictures it’s a 2014 2.2 110 station wagon
Post #1016672 28th Nov 2023 11:30pm
MK
Thanks. And what colour is it? Puma 110" SW
Post #1016677 29th Nov 2023 12:40am
Glen-I
Yes, it's a 110 in Corris Grey? (Did you mean the colour of my 110??) Or the colour of the Ashcroft uprated output shaft kit anodised sealing cup, which is red.
Post #1016685 29th Nov 2023 7:18am
PRENT1
United Kingdom 2011 Defender 110 Puma 2.2 XS CSW Santorini Black
output shaft failure
1. 2011
2. 2.2
3. Don't know. I havent changed in during my 5 year ownership
4. No failure (as far as I am aware) now 56,000miles
Post #1016693 29th Nov 2023 8:46am
Def90
United Kingdom 2015 Defender 90 Puma 2.2 SW Corris Grey
1. 90 2015my
2. 2.2
3. Yes
4. 62k miles still running, replaced while replacing the clutch.
It shows some signs or wear but was greased at 30k miles
When the TBox was removed
When refitting the cup to the gearbox out put shaft should you apply a locktite to the splines
As when it was removed it appeared to have been loctited from factory?
All I can find in the LR Workshop manual on fitting the cup is pre heating it to 100C before fitting?
Post #1023202 1st Feb 2024 11:28am
MK
AFAIK loctite is applied to the thread. It needs heating to expand a bit so you can fit it to the gearbox output shaft. And, yes sooner than later your output shaft coupling will wear out. Puma 110" SW
Post #1023209 1st Feb 2024 12:05pm
Def90
I’m going to try something a little different
For the replacement output shaft!
Post #1023310 2nd Feb 2024 11:25am
MK
I was tempted to take that route, but it was a scary to drill a hole into the extension case and possibly developing a crack. Puma 110" SW
Post #1023313 2nd Feb 2024 11:36am
Def90
Well just drilled a 14mm hole in the extension case and
I suppose I will find out in due course, and I do have a
spare just in case.
Post #1023316 2nd Feb 2024 12:16pm
