Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 66 of 107 <123 ... 656667 ... 105106107>
lightning
Ah okay that would explain it.
Post #1016012 22nd Nov 2023 1:09pm
lightning
pjeski wrote:
I'm posting this again because, while I have not tried it, the description seems to match what you are trying to accomplish:
Are you referring to fogs as corning lamps?
Try:
MultiCAN-784 Front Fog Funtionality
Front Fog and CL
I'm assumig CL means Cornering Lamps.
Changing the front fog functionality (Multican 784) from "fog lamps and CL" to "no additional functionality" did stop the cornering lamps from working.
However it resulted in a few other changes
lt's altered the way the DRL's work. Now, the headlights are on all the time on "auto" unless you turn them off, and then they stay off with no DRL's
The side lights can be turned on.
Before, the DRL's would be on all the time and if you turned them
off they would come back on within about 30 seconds.
Previously the headlights would only come on in low light conditions, unless you over ride the auto settings.
EDIT
The above is incorrect it didn't affect the main lights, that's how they work as standard and l never figured it out!
Post #1016014 22nd Nov 2023 1:41pm
pjeski
United States
After every ccf update, I email myself the ccf settings, then copy and paste the results into Beyond Compare, and then paste the differences into a document, noting why I made the changes. Makes for a good record.
Post #1016017 22nd Nov 2023 2:18pm
pjeski
United States
CCF Request
If anyone with a GAP tool has: (or close to it)
2023 Defender 130
Large PIVI screen
Full digital cluster (not analog) <- this is my issue
Please send me a copy of your CCF? I'd be happy to share mine in return.
Thanks!
Post #1016373 25th Nov 2023 6:32pm
holtenc
United States
DM'd
Post #1016375 25th Nov 2023 6:46pm
pjeski
United States
Greatly appreciated.
Post #1016376 25th Nov 2023 6:54pm
chpsk8
United States
One day I'm going to open this thread and its going to be an announcement about being able to clear the brake errors... someday... maybe for christmas that dream will come true... Very Happy
Post #1016377 25th Nov 2023 6:55pm
DefenderMidlands
jet-Pro software $99 is currently the only diy way to clear the brake errors. Gap hope to be able to one day with their tool. MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar
Post #1016379 25th Nov 2023 7:05pm
aajr
United States
Here's your answer (unfortunately, not simple, as you need an additional tool, personally I'm hoping the GAP guys will find a solution)
atldef110 wrote:
Good evening everyone. I'd like to share an enlightening experience I had today while updating the settings on my Defender 110. This will sheds some light on why the GAP IID3 tool might encounter issues updating certain features, particularly Adaptive Cruise Control, Park Assist, and others. Additionally, it provides insights into the source of the Emergency Brake Assist Error.
I believe I might be echoing something discussed by a colleague in a previous post, so please pardon any repetition.
First and foremost, I extend a sincere thank you to Ralph and Sarek Auto in Virginia for their invaluable assistance in resolving this issue. Their expertise and unquestionable knowledge about the vehicle were instrumental. If you're interested in learning more about their work, you can visit https://www.sarekautowerke.com.
For context, I own a 2022 P400 Defender 110, and all features are functioning flawlessly after this update. Further confirmation may be required by conducting tests on additional models.
Now, let's dive into the good and not-so-good aspects of our GAP IID3 tool.
The positive news is that we've collectively identified the correct keys that need modification to activate the Adaptive Cruise Control and Park Assist.
Regrettably, the downside is that the current version of the GAP IID3 tool (4.2.2 Build 162) fails to communicate with the right ECU module to implement changes made through the app. Which is the Driver Assistance Domain Controller (DADC).
During our recent experience, we applied all the necessary changes via the GAP tool to enable Adaptive Cruise Control and Park Assist, uploaded the Car Configuration File (CCF) settings to the vehicle, and, as expected, encountered the Emergency Brake Assist Error immediately.
Following the changes with the GAP tool, we connected the Land Rover tool to the car, performing a single action—calibrating (rewriting) the Driver Assistance Domain Controller (DADC). This process took approximately 30 seconds, and upon the car reboot, the Emergency Brake Assist Error vanished, and all features operated correctly. https://www.lrdefender.org/speed_control_d...n-630.html
An important detail worth noting is that each car's CCF, linked to its VIN number, is stored on Land Rover's cloud. While the GAP IID tool changes the CCF locally, it doesn't update on Land Rover's cloud. If you ever need to reprogram your vehicle at the dealer, they might overwrite your local CCF with the version on their cloud, which would result on a redo of all activations. The only way to keep your changes permanently in your vehicle is uploading the new CCF to Land Rover's cloud, which apparently is only feasible with the manufacturer's tool.
In summary, we all have a remarkable and user-friendly tool that empowers us to perform various tasks, including local feature activations, error identification, real-time performance monitoring, and much more. On the other hand, as with any software, ongoing improvements are inevitable, and soon we might have the capability to write on the Driver Assistance Domain Controller (DADC) which will allow us to activate features like Adaptive Cruise Control and Park Assist.
I trust this experience helps Patrick and the team to identify the missing elements and opens doors for expanded functionalities.
Keys used for the activation.
Important: This will not work with the GAP IID3 tool (4.2.2 Build 162). The current version does not update the Driver Assistance Domain Controller (DADC), which can be updated using the dealer's version.
Adaptive Cruise Control: (I probably changed more than necessary on this one)
EUCD-023 Cruise Control
Standard: Without cruise control
Change to: Adaptive Cruise Control Stop & Go
MultiCAN-503 IntelCruiseCtrl
Standard: Not supported
Change to: ICC not fitted
MultiCAN-580 PTCruiseFitment
Standard: Normal cruise fitted
Change to: ACC with Queue Assist fitted
MultiCAN-712 ACC Lead Car Dist Disp
Standard: Not fitted
Change to: Fitted
MultiCAN-809 ACC Stop Gap Setting
Change to: Fitted
Park Assist
EUCD-059 Parking Assistance
Standard: Without Parking Assistance
Change to: PDC (Front, Rear) - Parking (Parallel, Exit)
EUCD-099 Park Assist Camera
Standard: Without Park Assist Camera
Change to: With Park Assist Camera
EUCD-140 Pdcautoactivationmenu
Change to: With PDC Auto Activation menu
MultiCAN-469 PDCAutoActivation
Standard: Not Supported
Change to: Default OFF configurable
MultiCAN-500 PDCBtnFCIM
Change to: Fitted
MultiCAN-602 PDC
Standard: PDC not fitted
Change to: 10 Channel fitted ( Park Assist)
MultiCAN-786 Park Assist
Standard: Not Fitted
Change to: Full Auto VarD (Fully automated park assist with automated steering breaking accelaration and gears)
Post #1016480 27th Nov 2023 4:54am
lightning
This is very useful information, thank you.
lt also highlights a potential issue with the JET tool where you pay $99 for 72 hours use. lf the dealer ever resets your vehicle, maybe during a service, you'll need to pay a further $99 to enable the tool and re-install all your activations.
Post #1016488 27th Nov 2023 9:18am
nebc100
Luxembourg
Hello,
I activated most options in my D110, but forgot to activate the park assist when I had a 72 hour license for JET tool.
I have a GAP… can it activate these without getting the brake error?
Post #1016545 27th Nov 2023 5:28pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
It's on its way Wink Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1016559 27th Nov 2023 6:36pm
Hairy Dan
nebc100 wrote:
Hello,
No not yet. Has anybody got the park assist to work with the Jet software? Cheers Ian
Kielder 4x4 Safari
Post #1016560 27th Nov 2023 6:38pm
tooth_dr
Northern Ireland
Bow down Should I hold out on buying the jeppro 3 day licence?
Post #1016564 27th Nov 2023 7:15pm
dakluck
Does anyone have a CCF file for a US Spec L663 with Premium Headlights?
Attempting the LED -> Premium upgrade and have working main/high beams and squares, just no Halos.
TYIA!
Post #1016790 29th Nov 2023 11:37pm
