Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 65 of 110 <123 ... 646566 ... 108109110>
DefenderMidlands
They will defiantly need both keys so they should be telling people that as toy will have a wasted journey otherwise. Plus take activity watch if you have one MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar
Post #1015056 14th Nov 2023 8:51am
StromC
United States
chpsk8 wrote:
Weird, I just noticed that this morning. I was sitting at a light with a truck in front of me. My headlights were on, but my fogs were off. I turned my left signal on, and my left fog light lit up solid and my turn signal was flashing. Hadn't even seen that before.
I was wondering if it had something to do with the CCF file I had changed for the foglights. Sounds like it's a built in feature.
Yup - I am trying to figure out how to switch off this feature. I had a set of aux foglights fitted and connected via a relay to the factory fogs. Now though, whenever I turn on the indicators both the factory and aux fogs on that side light up. It was blinding drivers so I had to disconnect ther relay.
I have tried a bunch of settings but cannot find how to disable.
Post #1015204 15th Nov 2023 5:26pm
pjeski
United States
I'm posting this again because, while I have not tried it, the description seems to match what you are trying to accomplish:
Are you referring to fogs as corning lamps?
Try:
MultiCAN-784 Front Fog Funtionality
Front Fog and CL
I'm assumig CL means Cornering Lamps.
Post #1015276 16th Nov 2023 1:42am
mse
Thats a turn lighting feature - not fogs, its useful. on the rr is a moving light.
Been on LRs for years. Mike
Post #1015317 16th Nov 2023 2:59pm
lightning
l think it's a silly feature on cars.
ls there a setting in the CCF to turn it off with the GAP tool?
Post #1015380 16th Nov 2023 11:36pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
Try looking up 2 posts and you can tell us if it works Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1015384 17th Nov 2023 1:21am
lightning
l'll try it tomorrow and report back
Post #1015395 17th Nov 2023 9:42am
Vidoq
Qatar
Has anyone found how to activate video in motion?
249 - always allow video
didn't work for me ((
Post #1015808 20th Nov 2023 7:55pm
Brulz
Italy
Re: Speed accuracy
Pauljm wrote:
I set this to as I have 285x45r22 instead of 265x45r22 & the rolling diameter is bigger now 32.1
More accurate speed reading
MultiCAN-838 from: Speedo market 0- 3.5% + 2kph
To Speedo market 1- 2.0% + 0kph
When I set cruise control to 80 kph it does like 76 only. It gets worse the faster u go.
Anyone know why? It was teading low anyway?
You need to set the MultiCAN577 SpdoCalPercentScale to the right scale....
If MultiCAN-838 was set 2.0% --> MultiCAN577 must set 2.0%
You need to set also the MultiCAN575 SpdoCalkmhOffset to the right value...
If MultiCAN-838 was set +0km/h --> MultiCAN575 must set to +0km/h
Post #1015862 21st Nov 2023 8:23am
kenl
Australia
I was already happy with living with the speedo offset to the cruise set speed.... And then someone came along and solved it!! Thanks Brulz Thumbs Up MY23.5 SE Defender
Post #1015894 21st Nov 2023 12:52pm
PeteSkeet
United States
Does anyone know which specific option(s) in the CCF need to be changed to enable paddle shifters?
I have JET Pro now and can see all CCF options but I'm not sure which to change and I don't want to experiment too much.
Thanks!
Post #1015903 21st Nov 2023 1:36pm
Hairy Dan
I have the paddle shifters on mine but they were enabled by Hunters Prestige via Pathfinder, the only changes I can see from my CCF previous to having them enabled is
MultiCAN-536 GearboxPaddlesInDrive
change to Active in Drive
MultiCAN-537 SWSGearSelectors
Change to Fitted
This should also give you an option in Pivi to choose whether to be able to use the paddles in sport or drive/sport.
BUT, I had tried these settings before Hunters activated it and I couldn't get them to work so there may be another setting which isn't accessible to the IID tool yet.
Let us know how you get on Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #1015939 21st Nov 2023 8:04pm
PeteSkeet
United States
Figured it out finally with the help of this other discussion!
https://www.defender2.net/forum/topic90062.html
You were right, those were the 2 options that enabled the shifters in the CCF, but as someone else had mentioned previously in this thread, the DADC needed to relearn the new CCF changes for the paddle shifters to become active (they were discussing the parking assist but the same idea applies - both need DADC to relearn the CCF).
The link I provided above helped walk me through how to get the DADC to do it's thing using the 72hr copy of JET Pro.
Thanks again for everyone's help! Paddle shifters now working. Still need to play around with the software a bit more to get parking assist working.
Post #1015979 22nd Nov 2023 8:41am
lightning
Re: Speed accuracy
This did not work for me, l ended up with an "emergency braking not available" "2wd only" and the cruise control wouldn't engage.
l put the settings back to original and the faults cleared.
Post #1016005 22nd Nov 2023 1:42pm
DefenderMidlands
You would most likely need to also make DADC to relearn the CCF changes which you cant do with GAP tool yet, only with Jet Pro software MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar
Post #1016009 22nd Nov 2023 1:51pm
