![]() | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
malibu Member Since: 11 Sep 2023 Location: Melbourne Posts: 53 ![]() ![]() |
I would wait as I believe GAP is getting closer to a solution.
Nicofender Member Since: 16 Jan 2023 Location: Southern Posts: 51 ![]() ![]() |
How come? |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3037 ![]() ![]() |
I can confirm that this works if you want to turn off the cornering lamps. Change from "front fog and CL" to "no extra functionality required" |
Dammitdeano Member Since: 07 Nov 2023 Location: Brisbane Posts: 13 ![]() ![]() |
I’ve tried the settings as outlined in the sticky post on my 2020 P400S.
I’ve had success with Global Close and the Subwoofer activations. The TA icon appears on the passenger side of the PiviPro but when I select reverse I don’t get the options of ‘Start’. Nor any icons on the main button area. I tried to reconfigure and calibrate the trailer but it doesn’t seem to work as I expected. 😢 Any thoughts? |
stevemfr Member Since: 18 Sep 2022 Location: Strasbpurg Posts: 156 ![]() ![]() |
chpsk8 Member Since: 26 Sep 2023 Location: Midwest Posts: 45 ![]() ![]() |
Stay strong people! It's getting very exciting!
Well, that’s what I call solid news. Awesome guys! ✌🏻
aajr Member Since: 18 Dec 2022 Location: San Diego Posts: 42 ![]() ![]() |
sullivan1337 Member Since: 24 Oct 2023 Location: Pittsburgh Posts: 8 ![]() ![]() |
Does anyone know if we have the ability with GAP to change the behavior of the reverse park assistance sound?
It's annoyingly loud, and I literally mute it every single time I reverse or am in a parking lot/tight spaces. Can we either mute it by default, mute it all together, or have it remember the last state? 24MY Defender 110 P400 X-Dynamic SE, Pangea Green. |
coda0 Member Since: 07 Sep 2023 Location: Clearwater, Florida Posts: 5 ![]() ![]() |
If you adjust your volume when the "alert" is going off, it will remember it. I have mine on the lowest setting, but it is still pretty loud.
Down & Dirty Member Since: 15 Sep 2023 Location: Somewhere outback Posts: 79 ![]() ![]() |
When there beeping turn them down to desired level with radio volume knob
davewatson91 Member Since: 10 Dec 2023 Location: Canberra Posts: 1 ![]() ![]() |
So with access to Pathfinder, I enabled all the Park Assist options. I have got the menus, the graphics etc. The only thing that isn't working is the 'Start' button is permanently greyed out - even if I have multiple car space options to choose from; I can select the different spaces, but not click start - any ideas? |
tooth_dr Member Since: 26 May 2021 Location: Northern Ireland Posts: 237 ![]() ![]() |
Exact same as me and another guy with a D250 XS. Once the gap solution comes online it might be possible to work at it a bit more.
