Home > Puma (Tdci) > Washer jets
Page 5 of 5 <12345
Screbble
But it’s small…
Post #1014743 10th Nov 2023 8:09pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Mine's even smaller Shocked
I had replaced it with a Pierburg which increased the flow. Unfortunately it only lasted a year or two and I reinstalled the original. Sad
Post #1014838 11th Nov 2023 10:51pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
apt100 wrote:
One option is to buy new if you want some warranty etc http://www.mudstuff.co.uk/defender-programmable-wiper-relay.html
it is more expensive than a scrapyard etc but is still probably the best "bang per buck" mod there is Thumbs Up
7 years on the website has changed, so here's the current URL for the relay:
https://www.mudstuff.co.uk/products/defend...&_ss=r
Post #1015098 14th Nov 2023 6:26pm
macfrank
Just search for "Volkswagen Wiper Relay 99". Plenty of offers new and used. Smile
Post #1015126 14th Nov 2023 9:26pm
Learningasigo
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Corris Grey
During some light winter maintenance I tried to unblock my front washer jets. A needle didn’t help and in fact only made it worse. I used some compressed air (dust/air in a can) and sprayed directly into the nozzle. This worked an absolute treat and cleared both with easy using only a few seconds of air. Both worked fine for a short while….
I remember recalling the sound of air escaping in the bonnet during the clearing but assumed it was a straight feed to the pump and was probably some sort of expansion valve.
The system is now best described as ‘limp’. I haven’t seen any washer fluid leaking underneath, nor is the washer bottle empty. I wonder if I have blown the non-return
Thanks for any advice or possible areas to check for damage.
Post #1016941 1st Dec 2023 7:53am
Screbble
See reply in Technical section 👍
Post #1016944 1st Dec 2023 7:59am
GuJa
Germany 2008 Defender 90 Puma 2.4 SW Tonga Green
Well, I used the Pierburg too but had to change it also after one year. Why? See picture. It seems there is a difference between water and diesel or petrol Laughing
Post #1016961 1st Dec 2023 10:46am
macfrank
ahh, rust..., who would've thought - I certainly didn't Laughing
I forgot to open mine before binning it, so thanks.
Post #1017041 1st Dec 2023 4:23pm
Page 5 of 5 <12345
