Home > Puma (Tdci) > Inexpensive puma gear knob solution? |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 362 |
It is not sexy. A little more exotic...
12th Oct 2023 11:11am |
TriniDaddy Member Since: 23 Nov 2020 Location: 10.57422, -61.28906 Posts: 27 |
The Modeo knob seems to be threaded. Don't know what one will have to use to prep the exposed shaft for it.
I'm wondering if this would be a compatible replacement. https://www.lrparts.net/ukj500070wwm-knob-gear-change-lever.html 110 SW 2.4 IZUMI BLUE |
20th Oct 2023 1:50pm |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 |
Main issue is that the knob and the stick are one complete piece made with a metal rod covered in plastic.
To replace only the knob, you need to "destroy" the knackered knob and peel the plastic cover to expose the metal rod (handsaw and Dremel can be used). The rod (diam 18 mm +/-) doesn't have any thread, so if you like to use threaded knobs for it you must be sure that the diameter of the knob thread is less than 18 mm and then make the male thread in the stick rod accordingly and that can take some time if you don't have fast access to a lathe. So, the best cost/time solution (at least for me) was to produce a 3D printing knob and using a screw to fix it to the rod. Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
28th Oct 2023 4:31pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17461 |
When I did mine I found that the steel armature was 12mm OD, and was the perfect size to receive an M12 thread. It was nowhere near 18mm. Click image to enlarge |
28th Oct 2023 5:16pm |
Exactly. 12mm bolt diameter and therefore ideal for 12mm threads |
31st Oct 2023 3:01pm |
Opps!
My fault. I was just trusted in my memory (Not very trustable anymore) Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
3rd Nov 2023 11:41pm |
Kev the Rev Member Since: 04 Jun 2023 Location: Ripon Posts: 39 |
I used Quicksteel to reshape the gear lever where the plastic had peeled off and then used the silicone 6 speed slip on.
It fits well and feels lovely |
8th Nov 2023 11:45am |
Here’s what it looks like (if I can get it to load)
8th Nov 2023 11:47am |
ter11 Member Since: 28 Oct 2015 Location: Zurich Posts: 26 |
This rubber cover is a perfect fit for the td4. Many thanks for the hint!! Ordered it as per link and installed today. It looks and feels great.
21st Dec 2023 11:10am |
Click image to enlarge Anyone had any luck with this kit? https://www.amazon.com/dp/B09DYFVNKX 110 SW 2.4 IZUMI BLUE |
16th Feb 2024 5:28pm |
